Bearing knock?
  • Mohammed_A
    • 344
    Bearing knock?
    On a s50b30, how does one identify a bearing knock? what symptoms should one see , a knocking noise obviously but how loud and where?
    please help.... btw. the car still drives fine
  • 416stroker
    • May 2008
    • 2448
    your joking right? You better be or your a dumbass.
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
    • Mohammed_A
      • 344
      I might be a dumbass but i need to know, if its so easy then why didnt u just answer the question?
      • e30trooper
        • 11576
        Originally posted by mohammed_a
        i might be a dumbass but i need to know, if its so easy then why didnt u just answer the question?
        +1
        • flyboyx
          • 8371
          depends on how bad the knock is. i suggest buying one of those cheap mechanic's stethoscopes from harbor freight. just hook it up to your ears and set the probe on various parts of the engine until you hear the sound the loudest. if you think it is the lower end, put your car on a lift or jack stands so you can get under it with the probe. at least this will give you an indication. another thing to check would be your vanos perhaps. they have a tendency to make a clacking sound when they go bad. i don't think it would sound like a rod knocking, but then it depends on your mechanical experience whether you would recognize the difference. maybe a reputable repair shop would be a good idea also
          416 stroker: come on man. i have no issue with you, and it is true that you make a good contribution to this forum. it is also true that this guy could have asked his question a little more intelligently, but we don't need to talk to people like that here. i could understand if he was trying to come across as a douche bag, but he is asking a serious question. for me at least, this forum is about helping fellow members with advice. keep in mind that we all have different abilities. when i first started using this forum, i had a few butt hole responses to my posts. its not cool.
          Gigitty Gigitty!!!!
          • Mohammed_A
            • 344
            Thanks flyboyx.....
            im sorry but i could have asked it better i agree....
            anyway this is very serious for me....
            the thing that really getting me confused is when i used the car on a distance yesterday then the noise was there even when idling before i parked it off...
            This morning i started it up and the noise was gone.... maybe it comes with engine temperature??? the only slight knocking sound i heard this morning was the belt tensioner that was making a noise (came in contact with some water, rain)
            • 7pilot
              • 475
              Mileage?
              Did you change bottom end shells before the swap?
              If the knock is absent when cold, and comes in as the car warms up, then it is probably a rod bearing.
              Typically there is some slap that goes away as the engine warms, but converse behaviour is bearings.
              m
              • Mohammed_A
                • 344
                Originally posted by 7pilot
                Mileage?
                m
                the mileage on the motor since the build is 4000km... new bearing shells ....
                it comes after a long while after the car warms up... i did about 30km before the noise started yesterday from cold
                • 7pilot
                  • 475
                  Pull the pan and check the bottom end.
                  someone torqued the bottom end bearings wrong?
                  Noise from cold now may mean you have a spun bearing shell that has broken up.
                  Also pull the accessory drive belt off and check for loose drive pulleys....outside chance but can sound like rod knock as the pulley flaps.
                  m
                  • Mohammed_A
                    • 344
                    Thanks, gonna check it out
                    • Mohammed_A
                      • 344
                      btw.... is the noise supposed to get louder or softer with rising rpm?
                      • Spaz
                        Crazy Canuck
                        • 2276
                        IF you think its a belt tensioner, pull off the belt and listen. IF it goes away start your search there if it doesn't well now you can look closer at the engine.
                        !!!!!!!!!!DO NOT RUN YOUR MOTOR FOR VERY LONG WITHOUT A BELT!!!!!!!!!!!!!!!!!!!!!
                        !!!!!!!!!!!!!!!YOU WILL OVERHEAT IT!!!!!!!!!!!!!!!
                        I am not responsible for any problems that may arise following this procedure. This information is just that - information. Any work you do is at your own risk.
                        Cam .W '91 325is
                        Spaz's 1991 Alpine White???? S52 Build Thread...
                        • Mohammed_A
                          • 344
                          Dont worry, i wont hold u responsible for anything:nice:...
                          but i think that should be the first thing to see... thanks
                          • SpecM
                            • Oct 2005
                            • 4531
                            a rod knock will get MUCH louder with higher rpms
                            1989 cirrisblau-metallic 325i
                              • 34839
                              how is your oil pressure?
