To Vanos or not to Vanos...
  • motorsports_3
    • Mar 2007
    • 1058
    I am about to start a swap on my car, keep in mind it is a 88 325 super eta, or super slow. I found a great deal on a non vanos m50 from a 5 series for $400.00 including all of the accesories and harness. Since it from an e34 I dont need to deal with swapping the oil pan and all of that. The only issue is that it is non vanos.
    Should I keep looking? I do plan to boost it. I think for now a m50 with exhaust, headers, maf, and s/w should be quick enough for now, I may even boost it before I put it in. If I get an M52 id be spending around $1000.00 for the motor. I think the $600.00 difference is a nice start to a turbo system.
    Is the absense of vanos really that big of a deal in your guys opinion?
  • e30polak
    • 6136
    If you're planning to boost, the non-VANOS make tuning MUCH easier and less expensive. If you're planning on staying NA, then get a VANOS motor.
    INSTAGRAM: @UNDR8D_EMPIRE
    • xwill112x
      • Jan 2009
      • 4236
      if your gonna for sure boost it, go with the NV m50
      • Uber E30
        • 1409
        This... plus if you went with an OBDII engine you would need all the stuff for ODBI conversion so its even more of a savings than 600 bucks.
        -Alex
        • motorsports_3
          • Mar 2007
          • 1058
          Sounds good guys, I guess I will go with the NV, even stock it is a huge increase in power. Thanks
          I just have a question, would I be able to use the ecu from the Auto e34, of would I need a manual one?
          • matt
            • 3732
            There are no advantages and a lot of disadvantages for the non vanos M50.
            • Wh33lhop
              • 11705
              The lack of an old, rattly VANOS unit comes to mind... ;)
              Any comparative dynos of stock NV and TU motors? Would be interesting to see if the NV power falls off slower or not.
              paint sucks
              • madjurgen
                • May 2005
                • 1203
                ^+1
                With companies like TRM that offer good custom remote boost tuning, theres no reason to settle for the shittier internals in the NV motor.
                As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
                You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
                • motorsports_3
                  • Mar 2007
                  • 1058
                  Originally posted by madjurgen
                  ^+1
                  Are the internals really that much worse?
                  • matt
                    • 3732
                    Yes. Everything is heavier.
                    Heavier sucks.
                    The M52 is better yet.
                    Progress is like that. :)
                    • gregslow318i
                      • Sep 2007
                      • 1918
                      why not make a m52nv :pimp:
                      via nv head an a m52 short block
                      looking for a e30m50 swap harness adapter pm me $150 shipped
                      email nitroman12@gmail.com
                      • jrdeamicis
                        • Nov 2008
                        • 956
                        There is enough solutions now for dealing with the vanos that anybody is afraid of it is just silly.
                        Past Car : E30 S50 6 Speed 5 Lug 3.73
                        Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                        ___________________________________________
                        BNB Designs
                        Engine Swaps, Fabrication, Innovation, General Repair
                        Richmond CA
                        Julian 848-248-8029
                        • 416stroker
                          • May 2008
                          • 2448
                          True
                          84 318I Delphin RIP
                          87 325IS delphin 24v Sold
                          89 325 Alpineweiss
                          • e34john
                            • Apr 2006
                            • 3599
                            I've been thinking of putting a non vanos head onto the aluminum z3 block. That thread will come when I find a swap worthy car though.
                            I love the way a non vanos pulls, try one with swapped cams. so save those engines for us if you want to go with the vanos motors.
                            • Dissembler
                              • Jul 2008
                              • 153
                              An NV motor is down between 60 -80 lb/ft of torque... nuff said.
