Is it possible to pull codes through the e36 diagnostic port?
  • Lof8
    • Oct 2006
    • 2827
    Using a peake tool, is it possible to pull codes through the e36 diagnostic port on the engine harness?
    I was planning to buy a peake tool to help me pinpoint my s50 rough running problems, but I've been told that is not possible.
    Any help?
    S50'd
    Originally posted by TDE30
    What is this faggy shit I have happened upon?
    I can always live in a M3. Can't M3 a house.
  • e30s52
    • Oct 2007
    • 5235
    Any help?
    I dont know about the peak but I got my scan tool to work with my car through the obd1 port so I wouldnt see why not.
    www.gutenparts.com
    • matt
      • 3731
      Yes, it's possible. Otherwise what is the point of the peake tool?
      • Lof8
        • Oct 2006
        • 2827
        This is what I was told:
        "sorry but the peak scan tool will not work with the conventions as the e30 does not have a return for the data line trough the data port"
        I'm trying to pinpoint the cause of my rough running s50. I'm thinking that scanning with a peake may help, but am being told its not possible in an e30.
        Is there a necessary wiring through the adapter to power the scan tool?
        Edit: to clarify, we're all talking about the circular diagnostic port on the e36 engine harness.
        S50'd
        • FredK
          • 14759
          If x20 pin 22 is powered, then the Peake tool will work.
          • gregslow318i
            • Sep 2007
            • 1918
            once again only to reset the si light not pull codes
            looking for a e30m50 swap harness adapter pm me $150 shipped
            email nitroman12@gmail.com
            • FredK
              • 14759
              That's x20 pin 19.
              • robmespeedy
                • Oct 2004
                • 561
                You can pull codes from it.
                snap on scanner with the BM-1B Adapter for bmw.
                • robmespeedy
                  • Oct 2004
                  • 561
                  what scanner do you have?
                  • e30s52
                    • Oct 2007
                    • 5235
                    I got the modis to work with it and another one but I forgot the name of it.
                    www.gutenparts.com
                    • Lof8
                      • Oct 2006
                      • 2827
                      FredK, power @ x20 pin 22 will allow the scanner to function fully?
                      Greg, do I have power there? If not, Its gotta be easy enough to jumper some power to use the scanner.
                      I don't want to offend anyone or sound too stupid - It's just very frustrating to be so close but so far away from a clean running swap.
                      thanks guys.
                      S50'd
                      • FredK
                        • 14759
                        I am able to read codes through the diagnostic port. I had a VANOS code and a voltage supply CEL or something like that earlier this summer, that I used a Peake to find.
                          • 37828
                          I can pull codes just fine.
                          Classic BMW Specialists
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • 1990m3
                            • 1180
                            Peake works fine to pull codes on my car as well
                            • gregslow318i
                              • Sep 2007
                              • 1918
                              guess that my adapter pin combination does not allow it to pull codes with the peak but it does allow it to pull codes with other types of scanners, as alex has one of my adapters. so I guess this weekend I will got back and try running a 12v jumper to pin 22 @ the x20 and see if it works I'll get back to you and see what happens
