Is it possible to pull codes through the e36 diagnostic port?
  • e30s52
    • Oct 2007
    • 5235
    Originally posted by gregslow318i
    guess that my adapter pin combination does not allow it to pull codes with the peak but it does allow it to pull codes with other types of scanners, as alex has one of my adapters. so I guess this weekend I will got back and try running a 12v jumper to pin 22 @ the x20 and see if it works I'll get back to you and see what happens
    Yeah it worked fine on mine car when me and tom hooked it up. It had a 02 code but I got it fixed but this was with the first adapter you made me. I dont know if you made any changes to the new one or not. I can ask tom if he messed around with the adapter or not if you want me too.
    www.gutenparts.com
    • asubimmer
      • 6482
      Originally posted by MR 325
      I can pull codes just fine.
      • gregslow318i
        • Sep 2007
        • 1918
        no haven't changed anything between the 2
        looking for a e30m50 swap harness adapter pm me $150 shipped
        email nitroman12@gmail.com
        • e30s52
          • Oct 2007
          • 5235
          Do you have the peak at your house? we can try and see if its works when I am back.
          www.gutenparts.com
          • Lof8
            • Oct 2006
            • 2827
            and a follow up question...is the peake tool able to give me more than I can find through a simple stomp test?
            the peake tool is on order - my family has 2 other bmws, so its not just for my application, but hopefully it does something to help.
            S50'd
            Originally posted by TDE30
            What is this faggy shit I have happened upon?
            I can always live in a M3. Can't M3 a house.
            • surebimmer
              • Jan 2004
              • 978
              Peake tool works on all the swap car's i have used it on. That's 5 different swaps.
              • Lof8
                • Oct 2006
                • 2827
                Does it give you more codes than a stomp test is able to pull?
                S50'd
                • matt
                  • 3732
                  I don't think so.
                  • Lof8
                    • Oct 2006
                    • 2827
                    A little update here. The peake tool did not work when I initially plugged it in. I then put power to pin/wire 22 at the x20 via a 9v battery. It worked like a charm and gave me more codes than the regular stomp test.
                    Greg, maybe power this wire in future adapters? just a suggestion.
                    Sadly, it gave me nothing that pinpointed the obvious solution. I did find a possible vacuum leak, though. Hopefully she'll be going soon.
                    S50'd
