m52tub28 double vanos in e30? What parts from donor car?
  • fenixsz
    • Dec 2009
    • 6
    Hello,
    What I need from donor car to run Double Vanos m52tub28 in e30? It will be with OBDI II?
    It will be daily car and this torquer engine is on top of my wishlist!
  • hoveringuy
    • Dec 2005
    • 2754
    Very few people have transplanted the M52tu into the e30 and kept it OBDII. It is electrically challenging, but it can be done.
    • fenixsz
      • Dec 2009
      • 6
      well, m52tu is double vanos and obd 1 will not be possible?
      I am looking at m52, because it is lighter with his aluminum block and will balance the car. Stock hp's of this engine is enough for me.
      Most probably, I will look for whole donor car from UK, but I am aware of Nikasil problems of 90's engines.
      From wiki
      M52 engine in some markets, especially the UK, which had high levels of sulfur in the petrol during the late 90's. Sulfur acts as a corrosive agent against Nikasil and led to a lot of the early engines having premature bore-liner wear. Fortunately this problem was solved in post-September 1998 cars with the introduction of steel cylinder liners, with the designation M52 TU-3. However problems are still present in these engines so affected cars of this period should be bought with caution unless the service history verifies that work was carried out to rectify the problem. The American market M52 used iron sleeves from the beginning, and so, was unaffected by this problem.
      A Technical Update or M52TU version in 1999 added Double-VANOS and other modifications.
      So engine should be either post-September 1998 single vanos with steel liners or post 1999 double vanos.
      If I find single vanos, I can make it obd 1, but post-September 1998 will be very rare option.
      • z31maniac
        • 17566
        I think this is how hovering did it, but with a standalone VANOS controller.
        The guy is an electrical genius.
        www.gutenparts.com
        • fenixsz
          • Dec 2009
          • 6
          yep, I saw his thread about m54b30 - it's awesome!
          I know that m52tub28 and m54 are very similiar engines - how far I am from true?
          Are all parts needed for running stock obdi 2 m52tub engine in e30 in donor's car?
          • dirtysix
            • 806
            Use the m52.
            The nikasil was an issue with fuel that had high levels of sulfur added to it.
            Most countrys ran nikasil engines with no problems.
            I believe this is no longer an issue.
            • fenixsz
              • Dec 2009
              • 6
              Originally posted by dirtysix
              Use the m52.
              OK, but in this case I should avoid cars and engines from UK :(
              • MattM
                • Apr 2009
                • 931
                depends on what car the doner is... you will need other parts too.. read the stickys
                Full Build Thread Here
                • Major
                  • Oct 2007
                  • 82
                  How can you tell whether an M52 is OBD-I or OBD-II? I have one in my garage, no idea what the donour car is apart from a 328i automatic that had done 71'000 miles.
                  • fenixsz
                    • Dec 2009
                    • 6
                    As far as I know, all M52's are OBD II, but those with single vanos can be converted to OBD I.
                    • z31maniac
                      • 17566
                      Correct, at least state side. I can't comment on engine from other parts of the world.
                      The dual vanos M52 is the M52B28TU if I remember correctly.
                      www.gutenparts.com
                      • Major
                        • Oct 2007
                        • 82
                        Ah, thank you! Then my next question is, how do I know if it's a TU or not?
                        • 10Toes
                          Me Father Was A Tree
                          • Jan 2008
                          • 61222
                          It will be double vanos.
                          Double vanos
                          single vanos
                          • Major
                            • Oct 2007
                            • 82
                            Thank you! :) So I have an OBD-II single VANOS M52?
                            • hoveringuy
                              • Dec 2005
                              • 2754
                              Yes. That's single VANOS.
