Finally, some dyno numbers
  • Mr Two
    • Jul 2008
    • 590
    These were taken on a Dynocom dyno. Supposed to read somewhere in between dynojet and mustang dynos.
    CF was 1.01 for the last run, 44.1 degrees, 67% humidity, 28.19 in-Hg
    Crappy pictures!
    I'll scan it when I'm not lazy. I should have the file itself next week.
  • Mr Two
    • Jul 2008
    • 590
    Also I have videos.
    Also it might have fuel cut early due to the speed sensor being on the fritz (the clips holding it to the diff are broken, so it doesn't stay tight when the rear end squats under hard acceleration).
    Also I have some minor exhaust leaks and still have yet to get an x pipe fabbed up.
    Wooo!
    • Wh33lhop
      • 11705
      AAH! OH MY GOD!!
      What's done to the S52 in question?
      paint sucks
      • Mr Two
        • Jul 2008
        • 590
        :D
        Raceland euro SS longtube reps, dual 2.5" piping into a UUC System U, M50 manifold, 3.5" HFM, 3.5" shielded CAI, 3.5" -> 3" silicone intake boot, TRM chip, 12lb euro 323i flywheel.
        • E30Idea
          • Mar 2007
          • 2196
          Are you Corey Zusin????
          ** Lot's of M20 turbo parts for sale.**
          Turn key track car.
          http://www.r3vlimited.com/board/showthread.php?t=222066
          • Mr Two
            • Jul 2008
            • 590
            Yep, lol
            • ZM Blue Devil
              • Dec 2006
              • 13836
              damn, thats nice.
              Levent
              %20levent@gutenparts.com
              Ladies:
              • Mr Two
                • Jul 2008
                • 590
                According to the owner of the dyno, it usually reads about 8% lower than a dynojet
                • Mr Two
                  • Jul 2008
                  • 590
                  Also, a stock e46 M3 put down 258whp an hour later on the same dyno. wtf!
                  • sharksforthecup
                    • Aug 2007
                    • 246
                    247 whp w/ stock cams? Damn:p
                    • aeryk7
                      • Oct 2005
                      • 616
                      So how did you go up 10 rwhp from run to run
                      253rwhp
                      My Vids(OLD)
                      http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
                      http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
                      • e30s52
                        • Oct 2007
                        • 5235
                        Wow, great numbers
                        www.gutenparts.com
                        • lennon
                          • Jun 2008
                          • 1416
                          yeah OP what did you change between runs?
                          • JGood
                            • Jan 2004
                            • 7959
                            Looks like they cut the run short at 5650 RPM's, which makes the peak number lower since the s52 makes peak power above that RPM.
                            Yet another reason that looking at peak Dyno numbers is useless...
                            e30 restoration and V8 swap
                            24 Hours of Lemons e30 build
                            • jahnaboi
                              • Oct 2006
                              • 1742
                              Haven't seen that program before. Nice numbers nonetheless.
                              SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
