Finally, some dyno numbers
  • markseven
    • Sep 2006
    • 5327
    Originally posted by jahnaboi
    haven't seen that program before. Nice numbers nonetheless.
    +1
    I Timothy 2:1-2
    • z31maniac
      • 17566
      I'd say those numbers are a bit optimistic, but it looks like the TQ is smooth which is what matters.
      Not really sure about your A/Fs since I don't really understand their plotting system. Seems overly complicated for no reason.
      www.gutenparts.com
      • Wh33lhop
        • 11705
        Originally posted by Mr Two
        Raceland euro SS longtube reps, dual 2.5" piping into a UUC System U, M50 manifold, 3.5" HFM, 3.5" shielded CAI, 3.5" -> 3" silicone intake boot, TRM chip, 12lb euro 323i flywheel.
        Stock cams? Great numbers.
        Seriously! Unless the AFR is 16:1 between 4 and 5.5k and 10:1 everywhere else...
        paint sucks
        • Mr Two
          • Jul 2008
          • 590
          He cut off early in the first plot, but the 2nd and third runs he took it to redline, just their software does not always display correctly. I think the AFRs got thrown off by all the condensation I was spitting out the first run.
          • e30polak
            • 6136
            This. Those number are quite high for a non-cammed s52. Dyno probably reads 8% higher, not lower then usual.
            Great numbers nonetheless. I know those Racelands flow quite a bit better then the Ebay SS knock-offs.
            INSTAGRAM: @UNDR8D_EMPIRE
            • Mr Two
              • Jul 2008
              • 590
              It's not reading high, though. If it is, it was only on my car.
              The e46 M3 made 258whp. A Boxster S with what sounded like at least an exhaust made 243. My friend's Saleen F150, which made 310 on a Dynojet, made 289 on this and that's after an exhaust This was all within one or two hours.
              • e30polak
                • 6136
                If that's the case, then you have one of those freak s52s. Those numbers are way above average for you mods. :-|
                The numbers also explain your run in with that e92 M3.
                • C-T
                  • Jun 2008
                  • 300
                  Mr Two, I can't see it on the sheet you posted, and I'm curious - Are those numbers SAE corrected?
                  edit -
                  CF was 1.01 for the last run, 44.1 degrees, 67% humidity, 28.19 in-Hg
                  Sorry for not reading closer, I will assume the answer is no.
                  Chris | Debut Thread | Night Shots | Snow Shots |Youtube |60-130 |IP S52 91 325is
                  • Wh33lhop
                    • 11705
                    edit -
                    Even so, using that correction factor the difference between the two numbers would be 2.4hp.
                    paint sucks
                    • C-T
                      • Jun 2008
                      • 300
                      Nice!
                      • Skafrog
                        • 1732
                        IIRC that car has some cam work. It's been a few years though. Ask Herb.
                        NASA MidSouth TT Director / GTS2 #018
                        Mods: Coastal PS Fluid, 10w40 Oil
                        Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
                        • Mr Two
                          • Jul 2008
                          • 590
                          Really? That would explain a lot - I was under the impression it had stock cams.
                          • Mr Two
                            • Jul 2008
                            • 590
                            Just talked to Herb - he never had any cam work done
                            • LowR3V'in
                              • 4209
                              Most runs are sae corrected so people make
                              about the same numbers on the same setups, in different
                              places. You can see +20hp uncorrected compared to what
                              other people make.
                              Is your run sae corrected? Still must be running pretty good congrats!
                              • Adrian_Visser
                                • Jun 2006
                                • 2823
                                what chip are you running?
                                '89 Alpine S52 with goodies
