Originally posted by Mako18
View Post
Some concerns after putting m3 cams in my m50
Originally posted by JGood View PostDamn, that's weird. The first machine shop I went to did it as if it was a normal procedure. I think it was like $60, which included a resurface of the other side as well, and the whole thing came back looking like a new part.
So you still don't have enough clearance? If you want, I can take my spare flywheel and have it machined and send it to ya. PM me if you're interested.
Thanks, but I don't want to take it all back apart again. I think I have just barely enough clearance. It hasn't been a problem thus far, but I haven't driven the car much as I'm still working out the problems.
Machining the flywheel is definitely the better route though. Wish my shop would have done it! Good price too.Originally posted by z31maniacI just hate everyone.
No need for discretion.
ugh. update:
The low end power feels good. The top end power feels good. It pulls harder and harder to redline, feels like a Honda engine. Wish it was a bit flatter, but whatever.
My main problem is 4-4.5k. If I'm at 4k, and gradually go to full throttle by 4.5k, it will surge and stumble a bit as I'm depressing the pedal. Only once or twice, and when it gets to full throttle, it goes away. It's kinda hard to explain.
So I know this is a rather old thread but I do have a question:
Does the vanos have to make noise in order for it to go bad?
I feel like I don't have enough torque down low but once I get up to about 4500 rpms, it starts to pull.
This doesn't seem normal to me.world renown Harry Potter expert
Well I'm actually running an obd1 swapped m52. I have the s50 cams all ready to go in but I haven't pulled the trigger yet. I just feel like an m20 has more torque than me. I have thr top end power but the low end power doesn't kick in until about 4500-5000k RPM
Edit: if I unplug the vanos solenoid, what noticeable difference would I be looking for? Is it possible that the vanos solenoid itself went bad?Last edited by phreshkid; 03-18-2011, 08:46 AM.world renown Harry Potter expert
Originally posted by phreshkid View PostWell I'm actually running an obd1 swapped m52. I have the s50 cams all ready to go in but I haven't pulled the trigger yet. I just feel like an m20 has more torque than me. I have thr top end power but the low end power doesn't kick in until about 4500-5000k RPM
Yes, your solenoid could have went bad, but instead of throwing parts at it, I'd troubleshoot the system to see what is actually wrong.
So I've gone ahead and tried to drive both with the vanos solenoid plugged into the engine harness and without and to be honest? I didn't feel much of a difference. I can't say my tests were entirely conclusive since it's really wet outside and I was losing traction in the first three gears rather easily but I still didn't feel a difference. This sucks . What would be the next step to further verify my hypothesis other than waiting to drive it when it's dry?world renown Harry Potter expert
