M50 + zf 320+ 373 diff= no highway
    Originally posted by funcrew View Post
    My '69 Chevelle SS had a 3.91 diff and a big block, and obviously no overdrive. Brutal on the freeway, 8mpg or so. This was normal during the muscle car era, nobody thought anything about it.
    No overdrive, eh? So what was your top speed, 80mph? lol.
      Hi Matt T , 4th not 5th? So it looks like I need to buy a used diff to let the car run freely on the road.
        Personally, I'd go for a 3.46 if I was in your position. BUT, fi highway mileage is a concern for you the 2.93 would be best on gas, with the 3.23 (whatever it is) as the best compromise.
        I just hate everyone.
        No need for discretion.
          I get 25-28 MPG and I have a 3.25
            2.93 or 3.25
            I would not mind a 3.46 even without the 6 speed. The drive ability is worth it.
            Past Car : E30 S50 6 Speed 5 Lug 3.73
            Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
            ___________________________________________
            BNB Designs
            Engine Swaps, Fabrication, Innovation, General Repair
            Richmond CA
            Julian 848-248-8029
              So most of the dudes here with the same set up are running 2.93, 3.25 or 3.46. Well I am going to go look for one. It will probably come down to what's available of the 3 mentioned here.I am leaning toward the 3.25 because I cruise so much on the freeway.Thats just how I roll.
                if you're concerned with highway fuel mileage, 2.93 or the rarer 2.79 for sure.
                2017 Chevrolet SS, 6MT
                95 M3/2/5 (S54 and Mk60 DSC, CARB legal, Build Thread)
                98 M3/4/5 (stock)
                  4th :D get about 27 mpg
                  Full Build Thread Here
                    Went and took a look at a 90 535 and a 85 535 .The diff in these look different than our e30's. What is up? Do I need to swap the member out?
                      I have a 2.93 and roughly 3400-3500rpms @ 80mph
                      Turbo E30
                      Roadkill 80lb 93 octane OBDI tune
                      BavSol Cylinder Head
                      Stock S50 in. cam Schrick ex. cam
                      Otis' tubular T4 manifold
                      Oringed 87mm S52, Eagle rods and 8.5:1 CP pistons.
                      GT4094r w/Batmowheel Impeller
                      614whp@17.5psi, 100 Oct
                      690whp@21psi, 100 Oct
                      801whp@27psi, 110 URT
                      Old: 1/4 mile: 10.91@144.38 (636whp)
                      New: ?
                      http://www.youtube.com/watch?v=L_f7fUVqblI
                        I don't think an e34 diff will work, the e28 diffs will though. You swap the rear mount and output flanges.
                          Thanks Jean, Now, can I live with a diff without LS.I looked up the 85 e28 and it has the 3.25 gear set, so that might be the one for now. From what I was able to gather , not many e28 cars came with the LS diff.
                            Tons do man, i see them at pick n pulls all the time. I will PM you next time i see one.
                            -Alex
                              Don't get a 2.93. Your car will feel very unresponsive and slow.
                                Today was a good day. Thanks Uber e30,I took your info and went to (pick and pull) and sure enough I found a 535 with 119,000 miles and it had a big "S" on the diff . So the gear is 3.25. The oil that was in the bottom was golden. Can't wait to get this in the car, so I can get a highway pass.
