My M52 backyard swap almost complete - Some questions with pictures for the pros!
  • r4esh
    • Jan 2010
    • 439
    Just finishing up my M52 -> e30 swap. I'm done hours and hours of searching and my confusion is coming from different sources saying different things, so maybe you guys can help me sort this out... --->> It is an M52 motor with OBD1 Conversion. (manifold, wiring harness, dme, sensors, etc.)
    Question 1:
    MY power steering pump that come on the m52 doesn't have the normal hallow screw like I'm seeing most have... instead I have this (see picture) Any suggestions?
    Question #2:
    My Cam sensor plug is a male adapter and my cam plug on the wiring harness is a male plug???? Huh?
    Question #3:
    Intake & Hose routing questions (best described by photo).
    and
    Question #4 :
    Finally - I can't figure out the rest of the intake... I need a 'T' connect that goes from "???" then T's off one into the IDV and the Other into the PCV ? Then from there it goes PCV to the intake annnd IDV to "???"
    Oh man... If someone could fill in the blanks that would make a huge difference... Again everywhere I look it's either "now just hook it all back together and drive!" ooorrrr images so cluttered I can't distinguish a hose from a cable ooorrrr one person says 1 thing while another contradicts...
    Thanks guys! 8)
    - Dillon
    (oo=[][]=oo)
    Web Design PNW
  • r4esh
    • Jan 2010
    • 439
    Oh and finally...
    Question #5:
    I have 1 "cut" cable on my wiring harness.. dunno what it is, do you?
    Thanks again!
    (oo=[][]=oo)
    Web Design PNW
    • SamE30e
      • Sep 2007
      • 4319
      The one you cut looks like either the MAF, or the Charcoal canister.
      1985 325e 2.8 Turbo VEMS
      • White325is
        • Oct 2006
        • 5947
        Lolz at coolant res.
        • samiam3356
          • Jul 2009
          • 1901
          The hose at the back of the head goes to the bottom. Confusing lookng on REAL OEM.
          Originally posted by Roysneon
          $5 shipped?
          Originally posted by MarkD
          You are a strange dude, I'n not answering any more posts from you.
          • hoveringuy
            • Dec 2005
            • 2754
            Question 1:
            A. Use that connection, it's normal. High pressure supply to the rack has the banjo, low pressure return from the resevoir just use a hose clamp.
            Question #2:
            A. What wiring harness is on the motor? Do you still have the OBDII wiring harness installed?
            Question #3:
            Top one is the oil breather. DO NOT put coolant in there unless you want us to get a good laugh..
            Coolant expansion tank gets plumbed to the end of the metal pipe.
            I blocked my throttle body connections. No need, IMO.
            and
            Thanks guys! 8)
            - Dillon
            • r4esh
              • Jan 2010
              • 439
              I have one labeled MAF so I don't think it's that..
              (oo=[][]=oo)
              Web Design PNW
              • r4esh
                • Jan 2010
                • 439
                Thanks - Do you happen to know the part number for that hose? ... I don't have it, gatta order it. So then the metal T goes to the top?
                (oo=[][]=oo)
                Web Design PNW
                • hoveringuy
                  • Dec 2005
                  • 2754
                  You will need to do a continuity check between the cut wires and the pins on the ECU. You may also be able to tell from the colors of the wires.
                  • MikeDE
                    • 1873
                    Make sure you record the first startup attempts.....
                    -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
                    • r4esh
                      • Jan 2010
                      • 439
                      SO answers I've gathered so far.
                      Q1. - There should be a non-banjo fitting coming from the power steering res that clamps on the low presure side of the pump? .. I don't recall seeing this, but will look. The strange part is on the e30 there were 2 banjo fittings on the old pump and I have for sure, 2 banjo lines that reach the new pump... soo one of these isn't supposed to be there?
                      Q2. - The wiring harness is allegedly off of an OBD1 s50 m3... I say allegedly, because I purchased it from the forums... there are some differences from the Obd2 one that came off the engine i believe. Is it possible I have the wrong Cam sensor? Can anyone verify that the OBD1 is a male end or female end?
                      Q3. - I got the throttle hoses right. Then the line off of the back of the block goes to the BOTTOM of the heater lines and line coming off of the front goes into a metal line (came with the obd2) and then into the TOP of the heater lines against the firewall.
                      Then the metal line has a split that comes off - and the larger fitting goes to the Coolant Res.
                      Where does the oil breather go?
                      Q4. - I'm still a little confused about the intake lines / PCV and ICV. Can anyone give a breif description?
                      Q5. - not sure about which one is cut still. I will double check the color of the wires later and post.
                      Also I'm building a site dedicated to this swap, because I've passed a ton of misleading or not specific enough information on the web, so I will be sure to go into GREAT detail every step of the way.
                      (oo=[][]=oo)
                      Web Design PNW
                      • samiam3356
                        • Jul 2009
                        • 1901
                        This may help, Sure you have seen it but some of your answers are there.
                        Click here for parts numbers
                        $5 shipped?
                        • m_dudey
                          • 267
                          Question #4 :
                          Thanks guys! 8)
                          - Dillon
                          I'll help you out on your last picture.
                          -Your throttle body connections are correct.
                          -"what about this one?" goes to the coolant reservoir tank
                          -back of the head goes to the bottom of the heater core at the firewall
                          -"to coolant reservoir?" is not correct. that is your crank case ventilation. it should have a "valve" that plugs into the valve cover. off of that valve, should be a small and a big connector for vacuum hoses. the small nipple goes to the hose that connects your ICV to the intake manifold. the large nipple goes to the bottom of the intake elbow that connects the MAF to the throttle body.
                          -Brian
                          I should add that the above is for OBD1 hookup. OBD2 is slightly different. what are you running?
                          • samiam3356
                            • Jul 2009
                            • 1901
                            -Brian
                            Great point. My picture is for OBD2 as the title says m52. Didn't see anyhing saying OBD1.
                            $5 shipped?
                            • r4esh
                              • Jan 2010
                              • 439
                              Yes, it is m52, but I'm running OBD1 swap - I have OBD1 s50/m50 intake manifold - all OBD1 sensors (knock, cam, crank) - allegedly OBD1 wiring harness - and 413 Red Label DME.
                              So would the heater/coolant setup be differant if I was doing the OBD1 conversion? How about the intake stuff?
                              (oo=[][]=oo)
                              Web Design PNW
