Front Under Tray
  • markseven
    • Sep 2006
    • 5327
    Front Under Tray
    Did anyone reinstall the plastic under tray that runs across the front from fender liner to fender liner? If so, did you have to modify it a lot?
    I Timothy 2:1-2
  • ethrty
    • Nov 2009
    • 342
    makes for a PITA working on M20, im willing to bet it would be even worse with the S50
    • jahnaboi
      • Oct 2006
      • 1742
      Fits like stock with my s52. No mods necessary. I believe its a splash guard btw.
      SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
      • sharky
        • Jan 2005
        • 2672
        mine was cracked in half so I just used the fender liner parts and n**ger rigged it, i really need to get a whole piece one day or make a custom one.
        • browntown
          • Jun 2004
          • 3524
          meh, throw it away and install a skid plate. if it's intact, sell it to someone who really wants one.
          • SamE30e
            • Sep 2007
            • 4319
            My m50 pushes it down like a half inch, still fits.
            1985 325e 2.8 Turbo VEMS
            • graphikg
              • Jan 2008
              • 1614
              Mine fits. Bends down because of the pan tho.
              • topdown323
                • 248
                mine is currently a used oil resevoir for the leak i fixed. it drips a little to mock me.
                Firefighter/EMT, Paramedic class of 2010. Yeah, i save Lives.
                  • 37832
                  Mark, if you need one let me know.
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • markseven
                    • Sep 2006
                    • 5327
                    IIRC, it was easy to take off when I had the M20, but then again I have the BMP kit, no stock bumpers...
                    Aha! Splash guard... that's what it is. I couldn't for the life of me remember what that thing was called.
                    I have the EJ Night skiddy ;)
                    Good to know - thank you.
                    ROFL!
                    Matt - do want. What all do you have? I don't know if there is a difference between early and late model splash guards... my car is an '87... will the parts you have worK? I can swing by an get 'em sometime soon (the green car is going to TNG for some exhaust work).
                    I Timothy 2:1-2
                      • 34839
                      my car never had one.. I'd just take it out if it makes things a pain in the ass.
                      • markseven
                        • Sep 2006
                        • 5327
                        I would rather have it because right now the leading edge of the fender liner is missing, exposing the horn and ambient temp sensor. I'm sure there is no functional loss, but it just looks crappy when the car is parked with the wheel turned to the right. Also, with the BMP kit, I hate seeing the ground through the middle intake and the brake ducts. If the splash guard doesn't impede cooling to the oil pan, then I would rather have it in place.
                        I Timothy 2:1-2
                          • 34839
                          I have the ones on the sides (where the brake ducts attach) just not the one in the middle.
                            • 37832
                            Mark, I just have the undertray panel itself. It's from a late model, not sure if it's what you need but let me know.
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • markseven
                              • Sep 2006
                              • 5327
                              Matt, I checked realoem to compare PN's, but couldn't find that thing... I a ritard.
                              I Timothy 2:1-2
