Suggestion for swappers!!
  • isolatos
    • Dec 2009
    • 172
    I recently did my vanos m50 swap. I thought I had all of the bases covered:new water pump, thermostat, flywheel seal, shifter rebuild, etc-etc. One thing I never saw mentioned was to replace the gasket for the oil filter housing. It wasnt a bad job in the car but would be easier on a stand.
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    A complete top and bottom end gasket/seal set it is usually suggested, but not always done. Some people think intake and exhaust gaskets, and rear main seal with oil pan gasket and it's good to go, but not the case.
    • isolatos
      • Dec 2009
      • 172
      Yea. I did all the important ones but somehow missed this one, dont even remember seeing it mentioned. Of course mine leaked, it was very brittle when I took it apart. The heat killed it for sure..
      • RoadHazard
        • Sep 2007
        • 163
        I've heard about that before. On some people's car it becomes stiff and leaks so I changed mine out just for peace of mind. Mine was still in a good shape though.
        90 E30 S50B30
        http://www.fquick.com/roadhazard/
        • Jean
          • 18228
          It's pretty much common sense to replace old gaskets when the engine is on the stand, not just some gaskets.... imho
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            Yeah, and one would think that people would swap out plastic timing components when the overhaul their longblock.
            • isolatos
              • Dec 2009
              • 172
              Yea, I just missed this one somehow. Just trying to help others. It only took about 45 minutes to do in the car, but obviously way easier when its out. I havent seen this mentioned in the swap thread, thats why its here.
              • hoveringuy
                • Dec 2005
                • 2688
                Don't forget the two O-rings on the back of the oil filter housing. They seal the two galley plugs and leak!
                • jrdeamicis
                  • Nov 2008
                  • 956
                  Just did those today.
                  I do not think they sell them from BMW but I think the ORings are 22(ID)x2.5MM
                  Past Car : E30 S50 6 Speed 5 Lug 3.73
                  Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                  ___________________________________________
                  BNB Designs
                  Engine Swaps, Fabrication, Innovation, General Repair
                  Richmond CA
                  Julian 848-248-8029
                  • SamE30e
                    • Sep 2007
                    • 4319
                    True!
                    I neglected to change my oil pump stand gasket and it bit me in the ass after my swap.
                    1985 325e 2.8 Turbo VEMS
                    • RoadHazard
                      • Sep 2007
                      • 163
                      My rear main seal is leaking. Arrgg.
                      90 E30 S50B30
