dual cat /size for camd s50
  • brn2ply7
    • 301
    I am not sure weather my cats are too large some how. I wanted to run the cats immediately after the headers. I have two mac 2.5" hi-flow cats i would like to use that are off my old mustang exhaust. Exhaust will be all mandrel bent and stainless. Hoping for the 250rwhp club here, figure it will provide nice motivation for my project daily driver that's almost done .
    Engine will be as follows:
    -fresh s50 bottom end
    -fresh m50 head w/s52 valve train
    -minor pnp of head
    -shrick cams
    -24lb injectors
    -obd1 war chip
    -euro maf/3.5" c.a.i with shield/air box
    -m50 intake
    -dr vanos unit
    Exhaust questions/setup:
    -leaning towards the raceland headers
    -since they are 2.5" down pipe would it be ok to run two 2.5" hi-flow cats?
    -merge into single 3"
    -3" race muffler
    -3" oval tubing
    -3" muffler
    89 325i parts car
    90 325i in progress
    ground control 400f 700r-koni adjustables-koni adjustable sways-reinforced control arms-ground control camber plates-e36 cabrio shock mounts-4.10 lsd-5 speed swap in the works
    --tryng to join the schwarz army one day at a time--sigpic
  • MIKe30
    • Sep 2006
    • 2334
    buy my exhaust... if the racelands are euro reps like everyone says, it should bolt right up to them. Problem solved :)
    • brn2ply7
      • 301
      wish i had money like that lol
      89 325i parts car
      90 325i in progress
        • 34837
        why dual cats? sell them, go with a single 3" and be done with it.
        • brn2ply7
          • 301
          well i need cats in va as this is my daily project and they can hit u very hard for having no cats. not to mention i would think they would flow better than a single 3" cat.
          89 325i parts car
          90 325i in progress
            • 34837
            but with two Y's and two size changes, any slight increase in flow would be offset, plus the extra weight and packaging issues. a single 3" cat should easily handle 250whp..
            • brn2ply7
              • 301
              there would only be one Y and one size change...
              89 325i parts car
              90 325i in progress
                • 34837
                2 headers - Y - 2.5" pipe - 3" pipe - Y - whatever the stock size is
                that's two Ys and two size changes..
                • brn2ply7
                  • 301
                  The headers are long tube design and have a 2.5" outlet which would run straight through a 2.5" cat each then to the 2x2.5" >3" flowmaster y-pipe. rest of exhaust would be 3" all the way out the back
                  Just thought it would maybe help mid-range torque or something with the 2.5" down pipes being so large.
                  89 325i parts car
                  90 325i in progress
