m50 vs. m20 weight
  • screamingbmwe30
    • Jan 2005
    • 415
    m50 vs. m20 weight
    how much heavier is the 92 non vanos m50 vs. a 2.5 m20?
    thanks
    (looking for weights before and after swap if anyone has one.)
    also is the weight noticable when going around corners at speed?
    • 34847
    the M50 is heavier by around 45lbs. not likely to be noticeable at all, especially with more power. ditch your AC and get a lightweight flywheel and you'll be at less weight than a stock M20.
    there's a site that has all the BMW engine weights listed, maybe somebody will be nice and post it for you.
    • Brew
      • 3060
      Don't have any actual weighs, but the car understeered a little bit before the swap w/ GC 350f/475r, Koni SAs and stock sways and now feels more balanced. The Treehouse CABs probably have something to do with the better handling. As far as the weight, I think my front end is pretty close to stock since I removed the AC system.
      '91 318is
      • Addissimo
        • Mar 2004
        • 1820
        http://www.bimmerforums.com/engine_faq/
        read for yourself
        -Addis
        Doing something M50 related? -> http://www.addissimo.com
        On Myspace? ->http://groups.myspace.com/r3vlimited
        BF2142 SN = BillyGoose
        • Ryan Stewart
          I Love Miatas
          • 8978
          Ditto. The S50 is closer to 60lbs heavier but I ditched the AC and moved some stuff a bit farther back. I didnt ever run the AC so I couldnt tell you the difference. If you are really worried get a MA Shaw or IE hood.
          Im now E30less.
          • Beau B
            • Mar 2004
            • 734
            Josh, are you converting to M50 power now? :twisted:
            Beau
            1988 BMW 325iS
            • Screaming_bmwe30
              • 128
              What the heck....someone stole my identity :)
              • Beau B
                • Mar 2004
                • 734
                oops sorry I miss took you for Screaming_bmwe30
                Beau
                1988 BMW 325iS
                • screamingbmwe30
                  • Jan 2005
                  • 415
                  2.7 m20 owns you :P
                  • Charlie
                    kid tested, administrator approved
                    • 6686
                    Screaming_ guy, not the other one.
                    Did you run an event up at the OSU Ackerman lot back in like spring of 03?
                    I think I talked to you then, just trying to put faces to screen names ;)
                    Nando, fwiw, 45 pounds up front is a fairly noticeable amount depending on suspension setup, and a non-vanos M50 isn't that much of a step up from a healthy M20. That being said, you can tune that weight balance issue out a good bit with suspension, put a built M50/S50 in there, and it becomes irrelevant.
                    -Charlie
                    Swing wild, brake later, don't apologize.
                    '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                    FYYFF
                    • Stu Mc
                      • 4083
                      A complete M50 with accessories, a/c, manifolds, flywheel (remember stock is a dual-mass!) is around 427 pounds. I'm not sure what the weight is of a complete M20 with all accessories.
                      Remember where weight can be dropped with an M50!
                      -flywheel, stock is 27 pounds...run a 8-11 pounder.
                      -exhaust mani's. Run stainless OBD-2 mani's to save a total of 8 pounds.
                      -a/c--save 45-50 pounds with everything.
                      I dropped just under 75 pounds off the front of my 318 with these mods, and it will duck into corners like it should. I dropped another 50 or so out of the drivers seat, which helped drastically ;)
