dme and harness question
  • 89325iturbo
    • Mar 2004
    • 723
    If i were to get an s50 with out the dme and harness. what dme and harness can i use? do i have to find another s50 one or can a 325i 413 dme and harness work?
  • 5KWattson
    • Apr 2009
    • 809
    ODB1 vanos, 93-95 325i/is, 93-95 m50 e34 or 95 M3, im not sure what dme i think its a 413 red label...maybe
    "God created turbo lag to give V8's a chance" Taylor D.
    • nrubenstein
      • 3148
      All OBD-1 VANOS 325i harnesses are compatible. You'll want to a manual one as the automatic harness has a bunch of extra shit in it. (Although it will work too.)
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • nrubenstein
        • 3148
        If I recall correctly, the E34 harness ECU connector won't reach a properly bracketed ECU. It's much better to get an E36 harness than it is to add in that kind of iffy factor there...
        • 89325iturbo
          • Mar 2004
          • 723
          So a 325i/is manual harness and 413 red label ecu is fine to use with an s50 engine. Would you need a chip for a s50 in the ecu though
          • gregslow318i
            • Sep 2007
            • 1918
            Originally posted by 89325iturbo
            So a 325i/is/m3 manual/auto harness from a s/m50tu/ ie: vanos (build between 9/92 to 7/95) and 413 red label ecu is fine to use with an s50 engine. Would you need a chip for a s50 in the ecu though
            just fixed it for you not you dont need a chip to run it but you do need a chip for it to be tuned properly
            looking for a e30m50 swap harness adapter pm me $150 shipped
            email nitroman12@gmail.com
            • lennon
              • Jun 2008
              • 1416
              Yes, a 325i manual harness will work. And yes, a 413 red label ECU is fine to use, but you WILL need a chip for an s50. Either from an M3 413 red label DME, or from a company like The Racer's Market or Turner or whoever. They will just need to know what motor/mods and what DME.
              edit- Okay, like gregslow said, you dont neeeed a chip to run it, but I wouldn't run a 3.0 with a 2.5 chip. There's no reason not to get the proper chip...
              • 89325iturbo
                • Mar 2004
                • 723
                Thanks guys
                • Fusion
                  • Nov 2009
                  • 3659
                  On a similar note: whats the difference between a 403 brownish red and green label DME?
                  • gregslow318i
                    • Sep 2007
                    • 1918
                    nothing just the chip (program/tune)
