Going through Guibos
  • Bimmer335is
    • Jun 2006
    • 146
    Is anyone else going through Guibos like they are a pair of old sock? Feels great at first, everything is smooth and comfy, then as time goes by, not nearly as comfortable and feeling kinda bumpy.
    I think I have a problem with my engine sitting too high in the car. Its currently sitting on urethane engine mounts, and I keep tearing through the guibos. I know that my driveshaft is in line down the center of it, but I think there is too my angle from the transmission output shaft and putting stress on the guibo. Is anyone else having this issue with urethane engine mounts, and how would you suggest fixing it. I'm thinking i may have to fab up custom engine mounts but that sounds a little tricky.
  • Kev
    JMP Autowerkz
    • 1575
    you sure your driveshaft is balanced?
    "Hard Work Pays Off"
    1991-bmw 325i (R3vvd)
    1990- 325 (mpowa)(GC)(track)(beast)
    1988- 528e (daily driven when track car broken)
    • Mossman
      • Apr 2006
      • 1961
      You could try the e28 mounts everyone uses, they seem to hold my S52 pretty well. Also how is your center bearing?
      • Bimmer335is
        • Jun 2006
        • 146
        Well these are the e28 urethane mounts. And yes, the driveshaft is balanced. I guess I could buy the regular e28 mounts instead of the urethane ones.
        • Adrian_Visser
          • Jun 2006
          • 2823
          The yellow Ireland Engineering Urethane e28 engine mounts? Shit Those are what I'm going to be using for my swap I hope I don't tear through guibos.
          '89 Alpine S52 with goodies
          • Wh33lhop
            • 11705
            If your center support bearing is ripped up, there's a good possibility you're going to eat through guibos. Check that shit if you haven't already.
            paint sucks
            • Adrian_Visser
              • Jun 2006
              • 2823
              How tight were your U-joints? If they were super stiff they are probably binding which is common with older driveshafts, this will cause premature guibo and CSB failure keep that in mind.
              • surebimmer
                • Jan 2004
                • 978
                Wouldn't recomend the yellow ireland mounts or stock e28 green mounts. I've broke 3 sets of the stock e28 mounts and the yellow ireland mount have sagged so bad after only a year. I just swapped to the akg swap mounts they are nice. I have pictures of both mounts I'll post later.
                  • 34844
                  A) be careful of cheesy aftermarket flex disks. they aren't made the same as OEM.
                  B) it's possible to put them in backwards. They don't like it. Make sure the arrows point at the flanges.
                  • newman
                    • Mar 2007
                    • 1159
                    Buy a 1 piece driveshaft without a guibo?
                    1987 325is: 495whp/400ft-lb
                    UPDATED 03/12/10!: RB26DETT Swapped E30
                    • hugh jass
                      • 2220
                      what tranny/driveshaft combo are you running?
                      ______________________
                      ex-Chief Operating Officer
                      Blunt Tech Industries
                      West Coast and Pacific Rim
                        • 34844
                        Cover CEL and oil pressure warning lights with electrical tape?
                        • newman
                          • Mar 2007
                          • 1159
                          You're semi correct. There is probably a problem that needs to be addressed, however, guibos can still S a D.
                          • StereoInstaller1
                            GAS
                            • 22679
                            I was told the arrow points to the back of the car...at the dealership, by a tech.
                            What do you think?
                            That idea has been kicked around before. On domestics, the UJoint comes apart to allow installation of driveshaft...you are a M.E., come up with something better than BMW!
                            Closing SOON!
                            Thanks for 10 years of fun!
                            • JGood
                              • Jan 2004
                              • 7959
                              What do you think?
                              The arrows go towards the flanges... as in, both flanges. Each hole has an arrow, half point one way, half point the other. There are two flanges, trans and driveshaft.
                              e30 restoration and V8 swap
                              24 Hours of Lemons e30 build
