Consumption meter
  • Mohammed_A
    • 344
    Consumption meter
    Im running the s50 motor and finally fitted the standalone management, my question is, is there any way i can make the consumption meter work with the standalone management?
  • hoveringuy
    • Dec 2005
    • 2743
    It will work by connecting the fuel rate wire directly to the (-) side of one of your fuel injectors. That will give the needle life, but it won't be completely accurate.
    For 100% accuracy, you'll need a standalone version of one of my fuel correction boards.
    see www.seattlecircuit.com
      • 34844
      yeah, use hoveringuy's circuit, and connect it to an injector ground.
      • LowR3V'in
        • 4209
        That's the first time I've heard of those.
        I'm surprised they're not more popular. :0
        • Mohammed_A
          • 344
          Thanks alot, i gather that the fuel rate wire is the one under the cluster ( 3 wire plug-one is rev counter) ?
          the correction boards sound very interesting, do they just connect inline to the injector?
          im using 550cc Siemens injectors and the management has 2 (-) wires that control 3 injectors each, could i just tap into one of these wires? will your correction boards give me an accurate reading with the 550cc injectors?
          Whats the pricing of the correction boards?
          • Drew325is
            • Oct 2004
            • 520
            I'm using one of Hoveringuy's modules with my megasquirted M52B28...it's a brilliant. Over a 360km highway trip recently, the OBC and manually calculated values were identical! Steve's made a great contribution to the 24v E30 community.
            • Mohammed_A
              • 344
              anxiously awaiting Hoveringuy's reply
              • hoveringuy
                • Dec 2005
                • 2743
                In other words you have two banks of three injectors... banked injection. It will connect to one of those (-) wires.
                Yes, it will work but I'm not sure how the calibration on banked injectors would be. There exists the possibility that I would need to send you a second chip based on your feedback that has different calibration settings.
                The location of the wire depends on the year of the car. The late model cars have the fuel consumption signal running through the large plug (C101) earlier cars have it in the 3 wire plug behind the glovebox.
                • hoveringuy
                  • Dec 2005
                  • 2743
                  Kilometers? I thought I sent you one calibrated in grams of fuel per hectopascal!
                  • Mohammed_A
                    • 344
                    thanks for the reply, yes 2 banks, mine is an old 86 model chrome bumper, i know that its on the c104(i think its called that) i got the rev counter wire off the same plug...
                    how much would the board cost?
                    • hoveringuy
                      • Dec 2005
                      • 2743
                      It's still only $90, shipped.
                      • Drew325is
                        • Oct 2004
                        • 520
                        Yeah, but that's technical talk...you don't need to worry about that :)
                        Such a great little gizmo...it's nice having the OBC behaving as it should, even with the MSEFI and 24V. Definitely gives the project a good sense of completion.
