M54 - S50 comparison
  • gregslow318i
    • Sep 2007
    • 1918
    all stock s50 w/dinan chip stock e30 cat/mid and muff obd2 headers
    looking for a e30m50 swap harness adapter pm me $150 shipped
    email nitroman12@gmail.com
    • Dominic49
      • Feb 2007
      • 1373
      Originally posted by JGood
      It does. Different dyno's, different conditions, etc...
      the s50 and s52 were dynoed same day one after each other in the same conditions.
      • Dominic49
        • Feb 2007
        • 1373
        there
        • matt
          • 3732
          Check the cam timing on that motor, you probably have the intake cam a bit advanced.
          • hoveringuy
            • Dec 2005
            • 2751
            Greg,
            I can measure your cam timing electronically. I would need another motor with known, good timing to compare it to.
            • nrubenstein
              • 3148
              Greg's torque curve looks like my S50 felt before I replaced the VANOS seals earlier this week. Well worth the $30 Beisan kit.
              2002 BMW M3 Alpinweiß/Black
              1999 323i GTS2 Alpinweiß
              1995 M3 Dakargelb/Black
              - S50B32/S6S420G/3.91
              1990 325is Brilliantrot/Tan
              1989 M3 Alpinweiß/Black
              • balooshinakus
                • 511
                Steve, if you want to get dynoed back to back against my s50 I'm free on weekends. Just let me know when you are settled in with your move and everything.
                • MIKe30
                  • Sep 2006
                  • 2334
                  I bet it is just that exhuast being super restrictive. Un-choke that bitch.
                  • e30s52
                    • Oct 2007
                    • 5235
                    I think greg just used the stock e30 cats and pipes so it isnt that bad but could be alot better.
                    www.gutenparts.com
                    • gregslow318i
                      • Sep 2007
                      • 1918
                      already did the beisn kit, cam timing is correct, I already know what the problem is but Im to lazy to fix it.
                      it needs a new fuel pump and the injectors cleaned also the exhaust would help a lot....
