Head/Vanos Question
  • isolatos
    • Dec 2009
    • 172
    Head/Vanos Question
    So my head is cracked. If I buy a complete head that has already been checked out is there any need for the vanos tools etc?
    Thanks
  • FredK
    • 14759
    Yes. You will need the cam blocks at a very minimum to reinstall the new head.
    • isolatos
      • Dec 2009
      • 172
      I guess this whole vanos system still baffles me. I have done plenty of head gaskets before and just been able to line up the cams when the no.1 is at tdc.
      • FredK
        • 14759
        Ah, in order to get the Vanos installed, you don't necessarily need the round turning tool. However, it helps. You also don't NEED the dummy tensioner.
        To set the cams properly, the blocks will be best. It's hard to eyeball how vertical the vertical flats on the cams are.
        • isolatos
          • Dec 2009
          • 172
          Right on. Thanks a lot. I am gonna see if the dealership will loan them to me for a night. I was talking with a member and he hasnt gotten back to me.
          Thanks
          • ethirdy
            • Nov 2007
            • 406
            What about disassembly? Any special tools? Or just remove tensioner, etc?
            Originally posted by alpinaclone
            Since the real economy is in the shitter, I say we start our own.
            This is how it works; you buy my junk, then I will buy more junk and so on so forth etc. etc. Think of the future of your children and buy my stuff.
            • FredK
              • 14759
              Disassembly without special tools is possible. You just need to be very careful during the cam removal process.
              There is a writeup on Pelican Parts on cam removal that can help you visualize what it is you need to do.
              • bernzpeed
                • 3917
                YouTube us the best. I disassembled my m50tu with their help
                Sent from my HERO200 using Tapatalk
                89 E30 S52
                Transaction Feedback.
                • e30 s52
                  • 100
                  u can also make one...they have all the dimensions in repair manuel at autozone
                  • e30serg
                    • Dec 2006
                    • 562
                    From what I remember, the tool doesn't hold the cams so that the flats on top are horizontal. Don't do it without the tool.
                    • jrdeamicis
                      • Nov 2008
                      • 956
                      Cam locking tool and vanos turning tool are REQUIRED for a proper vanos install.
                      As far as removing the cams, always remember as soon as one nut is loose one goes tight. No more than a 1/4 turn at a time.
                      Past Car : E30 S50 6 Speed 5 Lug 3.73
                      Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                      ___________________________________________
                      BNB Designs
                      Engine Swaps, Fabrication, Innovation, General Repair
                      Richmond CA
                      Julian 848-248-8029
                      • bernzpeed
                        • 3917
                        this
                        89 E30 S52
