G260 + m50...
  • El Gato Liso
    • Jun 2008
    • 44
    G260 + m50...
    so, I know I am not the only one who had an issue of the lower 4 bolts bolting into the oilpan.
    is it alright to leave those 4 bolts out?
  • Wh33lhop
    • 11705
    Yes.
    paint sucks
    • hoveringuy
      • Dec 2005
      • 2715
      Does that mean the oil pan will drop without removing the tranny?
      • White325is
        • Oct 2006
        • 5947
        No.. you still don't have access to the back oil pan bolts.
        • Adrian_Visser
          • Jun 2006
          • 2823
          So are you guys drilling holes in the bellhousing for access or what?
          '89 Alpine S52 with goodies
          • White325is
            • Oct 2006
            • 5947
            no, just loosen up the trans and slide it back 1/4 inch to be able to have access to the bolts. You should have to remove anything to do that.
            • hoveringuy
              • Dec 2005
              • 2715
              I'm not planning to remove my oil pan, but if I ever get the oil pressure light I'll know what needs to be done..
              • Adrian_Visser
                • Jun 2006
                • 2823
                You need a clutch alignment tool for a g260 too don't you? Grr I went to install my clutch tonight and it became apparent. Anybody know where I can pickup a clutch alignment tool without buying a clutch kit?
                • j0oftheworld
                  • 480
                  If you have enough people you can always align the clutch w. the trans.. haha
                  100lbs clutch alignment tool! :)
                    • 37829
                    That makes no sense.
                    Classic BMW Specialists
                    Grover Beach, CA
                    www.BimmerHeads.com
                    • genocide98
                      • Oct 2009
                      • 106
                      I just eyeballed it with a deep well socket on an extension with my m10/g240. it took a little while to get it right tho.
                      edit:
                      To be fair the motor/trans were out of the car on the garage floor... so that might make a significant difference.
