No fuel, but cranks well!
  • BustaRhymes325i
    Gaping Anus OG
    • Aug 2009
    • 243
    OK. So close to being done on my swap, its now frustrating that im getting no fuel.
    I can crank the car and I hear no fuel pump. When I turn it to accessory I would typically hear it run, but now I dont. When I jump the green/violet wire and the red wire on the fuel pump relay, I can hear the fuel pump run. With this jumped and cranking the engine, I still dont smell any gas coming out of the header (havent hooked up the exhaust yet)
    I dont know what is happening or what to check next.
  • M-technik-3
    • 18946
    sure you have the lines running correctly? Very common to have them reversed.
    • BustaRhymes325i
      Gaping Anus OG
      • Aug 2009
      • 243
      Ill recheck them.
      • BustaRhymes325i
        Gaping Anus OG
        • Aug 2009
        • 243
        Lines are correct. Just check them. I jumped the said wires above, and fuel came shooting out. I have the supply connected to the front of the fuel rail. What should I check next?
        • MattM
          • Apr 2009
          • 931
          are you getting spark?
          no fuel/no spark is the DME's way to disable the engine, this could either be from an error, or EWS(what DME do you have?)
          Full Build Thread Here
          • BustaRhymes325i
            Gaping Anus OG
            • Aug 2009
            • 243
            I believe I have a red label 413 ECU. I also dont have my MAF plugged in because the pins are incorrect (6 pins on MAF, 4 on connector). This wouldnt prevent it from firing in some way would it?
            • jahnaboi
              • Oct 2006
              • 1742
              No, the MAF disconnected would not prevent it from firing. Double check that all your relays are in the right relay holder. There should be 2, 4 prong relays with no center prong. The main relay should have 5 prongs. Make sure they are in their corresponding spots. Simply count the number of leads connected to the plastic housing and plug in the corresponding relays. (5 leads, 5 prong relay, 4 leads, 4 prong relay).
              If you don't have spark, and no fuel, it could be easy as the main relay. If not, check the dme plug if the DME is getting power, and if the CPS sensor is sending 500 - 1000 ohms to the DME.
              SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
              • sharky
                • Jan 2005
                • 2672
                is your chip installed correctly (tab facing the right way)?
                • gregslow318i
                  • Sep 2007
                  • 1918
                  do you have a good crank signal? is your check eng light on? have you jumped the fuel pump relay to see if it works ?
                  looking for a e30m50 swap harness adapter pm me $150 shipped
                  email nitroman12@gmail.com
                  • BustaRhymes325i
                    Gaping Anus OG
                    • Aug 2009
                    • 243
                    I will check these relays. Ill see if I can check the crank sensor too.
                    I will check this as well.
                    I jumped the fuel pump relay, and when I do I can hear the fuel pump run.
                    • BustaRhymes325i
                      Gaping Anus OG
                      • Aug 2009
                      • 243
                      Ok, pulled 2 coils and tested them both, looks like im getting no spark as well. I pulled the ECU and popped the top. First time ive done it so Im not sure what Im looking for in terms of the chip. Here is a pic of it:
                      • M-technik-3
                        • 18946
                        The white plastic cover is for the chip. Looks like it's the right orientation, looks like factory chip.
                        • MR E30 325is
                          • Dec 2008
                          • 3300
                          You have an EWS problem.
                          purchase an EWS delete chip, or get a red label 413
                          I had the same problem a few months ago.
                          My previous build (currently E30-less)
                          http://www.r3vlimited.com/board/showthread.php?t=170390
                          A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                          • BustaRhymes325i
                            Gaping Anus OG
                            • Aug 2009
                            • 243
                            Thanks
                            This is a red label 413 ECU. Shouldnt have and EWS that I know of...
                            • jrdeamicis
                              • Nov 2008
                              • 956
                              Do you have a CEL?
                              What is the resistance of your Crank position sensor?
                              Past Car : E30 S50 6 Speed 5 Lug 3.73
                              Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                              ___________________________________________
                              BNB Designs
                              Engine Swaps, Fabrication, Innovation, General Repair
                              Richmond CA
                              Julian 848-248-8029
