No fuel, but cranks well!
  • BustaRhymes325i
    Gaping Anus OG
    • Aug 2009
    • 243
    Originally posted by jrdeamicis
    Do you have a CEL?
    What is the resistance of your Crank position sensor?
    I do have a CEL, but it also may be from my purge valve not being connected...
    • jrdeamicis
      • Nov 2008
      • 956
      So where are you venting the throttle body to? Do you have it sealed?
      Past Car : E30 S50 6 Speed 5 Lug 3.73
      Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
      ___________________________________________
      BNB Designs
      Engine Swaps, Fabrication, Innovation, General Repair
      Richmond CA
      Julian 848-248-8029
      • BustaRhymes325i
        Gaping Anus OG
        • Aug 2009
        • 243
        I have an end cap/vaccum cap on the end coming off the TB. PO had done the M50 swap previously and deleted it. Then now im doing s50.
        • BustaRhymes325i
          Gaping Anus OG
          • Aug 2009
          • 243
          Just checked resistance on my crank position sensor, reads .535K Ohms, or 535 ohms in other words. I believe this falls within tolerance if I have searched the other threads correctly...
          • MattM
            • Apr 2009
            • 931
            did you remove the engines wiring harness at all? if so go back with the ETM and make sure you plugged all the sensors and accessory's into the right wires, some of them are very easy to get backwards, and depending on what they wont let the engine run. This was my reason for not getting spark or fuel when i first did my swap,but i cant remember now which 2 it was that i got backwards...
            Full Build Thread Here
            • jahnaboi
              • Oct 2006
              • 1742
              Have you checked the relays?
              SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
              • BustaRhymes325i
                Gaping Anus OG
                • Aug 2009
                • 243
                To answer your question, no I did not retain my harness. I got a new harness.
                No I have not. I dont have any spare relays.
                • jahnaboi
                  • Oct 2006
                  • 1742
                  That wasn't what I meant by check the relays. Have you checked that the correct relay is within the correct plug? 5 prong relay to 5 prong plug, 4 prong to 4 prong.
                  The reason why I ask is because when I purchased a motor for one of my customers swap, they changed the relays around which caused the car to have the same symptoms. No spark, no fuel. Everything check out, and it was just mixed up relays on the wrong plugs.
                  • BustaRhymes325i
                    Gaping Anus OG
                    • Aug 2009
                    • 243
                    Oh, sorry, yes. I checked and the 5 prong relay is in the 5 prong slot, and the 2 4's are in their respective slots. Now Im wondering if these 2 relays that have 4 prongs are the same or not, or if i can switch them around to test...
                    • jrdeamicis
                      • Nov 2008
                      • 956
                      Relay testing.
                      For the picture.
                      Apply +12V on pin 86
                      Ground to 85
                      Read for voltage (+12V) on 87
                      And use -12V on your ground on the meter.
                      You can check the 4 pin relays that way.
                      The 5 pin relays if I remember correctly will have a 87 and an 87a.
                      With power you should have 12V on one of them
                      With no power you should get power through the other.
                      BNB Designs
                      Richmond CA
                      Julian 848-248-8029
                      • jrdeamicis
                        • Nov 2008
                        • 956
                        Put a jumper in between 86 and 87 to bypass the fuel pump relay for now. For testing.
                        555 is fine for the CPS.
                        Did you meter that @ the ECU connection ? (x6000)
                        BNB Designs
                        Richmond CA
                        Julian 848-248-8029
                        • BustaRhymes325i
                          Gaping Anus OG
                          • Aug 2009
                          • 243
                          I metered it by unplugging the CPS from the harness, and puting the two test leads on the volt meter on 2 separate prongs.
                          • MattM
                            • Apr 2009
                            • 931
                            go back and make sure you plugged everything in correctly, Use the ETM and go by wire color, its VERY EASY to plug something in wrong, and 1 thing wrong could cause all the symptoms you have.
                            • dirty30
                              • 3099
                              Check ground at the DME.
                              • jahnaboi
                                • Oct 2006
                                • 1742
                                You guys do know that the ECU has an internal ground right?
