Trying another ECU tonight. Where am I checking this ECU ground at, if anyone knows off hand?
No fuel, but cranks well!
Ok heres where im at:
Tried another ECU (has a blue label 506 on it) which yields spark and fuel (at least I think, because it is backfiring). The problem is, when I depress the ignition key, it cranks like 5 cranks, stops, then cranks 5 cranks, stops, and will occasionally backfire in there somewhere.
When depress the ignition key with my 413 ECU (the original ECU in this thread), it cranks and doesnt stop until I stop pushing the key down. So it behaves completely normal, just isnt giving me spark or fuel.
Idk im stuck at a crossroads. Seems like I almost need to try a 3rd ECU or something. Maybe I am overthinking this?Comment
Cranking is not sensor dependent. Its a simple circuit for the starter.
Start with why its not spinning all the time. Look for +12V at the body connector. C101.
If you are getting +12V on ignition @ the starter. I would go with your starter is acting funny.Past Car : E30 S50 6 Speed 5 Lug 3.73
Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
___________________________________________
BNB Designs
Engine Swaps, Fabrication, Innovation, General Repair
Richmond CA
Julian 848-248-8029
Ok, Ill check this. It just seems odd though that when I swap between 2 ECUs that it cranks normal for one ECU, but not the other.Comment
So, what does it do when there is NO ECU and you are cranking?Past Car : E30 S50 6 Speed 5 Lug 3.73
BNB Designs
Richmond CA
Julian 848-248-8029
Just an update, car is running:
When I did the swap, i was converting from a 92 325i NV. I reused the crank wheel in the front, which is apparently different from what is needed on my S50, so this was issue 1. Issue 2 may or may not have been my crank sensor. The car started with this one, but it was bashed up for some reason. Issue 3 is that my 413 ECU did not start the car, but a loaned shop ECU will start the car. I believe all other wiring, etc was correct.
Consider this resolved. Thanks for all the help.Comment
Why the hell were you trying to use a 413 on a NV engine? you need a 403 or 406 DME
'89 Alpine S52 with goodiesComment
Well the wiring harness from a NV engine does not actuate the vanos so how is that getting power?Comment
