True dat.
So are you with NASA? Have you been doing it for a while? Have I seen you out there before? I'm assuming you track an E30? What group are you in?
Sorry for all the questions, but I'm always curious about those things.
Update:
So I've finally been doing some real boosting. I have my 50mm Synapse WG plumbed for lowest boost setting along with having the stiffer main spring and smaller valve seat installed for quicker spool. So all that equates to me getting a whopping 4.2 psi, lol. Good enough for break-in period ;)
This places my exhaust back-pressure at about 8.7psi, which isn't the worst thing in the world, but my last setup had less (about 1:1). According to Synapse's manual, putting the larger valve seat back in should help a little. My car already spools very quickly (and that's with the pre-load spring at it's lowest setting) so I'm going to try the larger seat.
One thing to note is that I am making MUCH more exhaust gas by volume with E85 and I still have that damn cat in my exhaust, so I feel safe saying that's my main source of increased back pressure. Need to make that damn test pipe already.
So far so good though. No signs of any issues and spark plugs look great, but they make it apparent that my timing is too retarded (15 deg @ 4psi). It's just a base spark map, so oh well. I'm going to take care of that on the dyno.
Idle is awesome and rock solid. Even better than stock. Like better than in my E36 M3 stock! None of that hunting bullshit. It's amazing how one little thing I learned on Supraforums about tuning idle on the AEM has done so much. Also, my drivability is also leaps and bounds better than before. Feels very stock.
There is one issue, though. My compressor housing got so damn hot today that my intake filter has began to melt! :o
I could place my entire hand on my turbo blanket, but just barely touching the compressor housing was like touching a hot stove, ouch!
Has anyone ever had this happen? I know it's hot in AZ, but damn! Can the blanket be to blame?
Update:
