Cam timing
  • rammstein
    • Jul 2009
    • 367
    I don't remember the exact number, but I paid more than $400. Active Autowerke did the fix, and their labor is pretty damn expensive. That being said, it was also done right, so I can't complain. Especially because they are the ones who pointed out to me that my issues were likely from that and not an ecu issue as I had suspected, so kudos to them too.
    I hope that your issues turn out to be simply from the timing, because if they are when you get your car back it will feel AWESOME.
    E30 M52B28
    • matt
      • 3732
      Hm. I need to raise prices, apparently.
      I'd do a cam retiming for $250 + valve cover gasket any day of the week.
      • hoveringuy
        • Dec 2005
        • 2751
        I've wanted to develop a little bit of electronics that would read the crank and cam signals to give an EXACT timing readout for either cam. I'm already doing that with the VANOS controller, I would simpify and shrink it down to a standalone unit.
        I know that BMW can read the ECU to get that data on the newer cars, not sure about our motors.
        • ForcedFirebird
          • Feb 2007
          • 8300
          Really depends on location and client base. BMW dealers here charge over $150hr and indy's are in the $90-$120 area.
          OBD 1 or 2? Any high end scanner can read OBD2 cam positions.
          john@m20guru.com
          Links:
          • 328ijunkie
            • May 2007
            • 3961
            Me too! lol
            Check Us out on Facebook
            Full Product Line Tuning
            • graphikg
              • Jan 2008
              • 1614
              ^^^ and
              If any of you were closer, I would have taken the deal.
              Trust me, I also hope its just timing. Its been over 8 months without driving this car. If it comes back tip top, I will be pretty content with my car to say the least.
