I used a black fiberglass wrap from Prosport gauges. The advantages are it helps keep the heat in the exhaust and away from my wiring and a/c lines.
My M52TU Swap
Hey guys I just finished my instrument cluster and was hoping to see what you guys thought. I think it turned out ok, considering the limitations. Since I didn't have any nice new plastic to use, I had to use the original clear plastic front and it has a hole in it that I couldn't get rid of. Oh well, I guess I will just have to deal with it till I can make a new one later.
Thanks. It took me a while to get as close to perfect as I could. Spent a little more time at it and installed the instrument cluster column and cover pieces. Looks like it was meant to be that way. The only thing that is pissing me off, is the LCM. I don't have enough time before I leave to CA to fabricate a good looking piece for holding the LCM in the dash and not look like crap. For right now it will hold, but I will have to fix it soon cuz it will drive me crazy looking like it is.
yeah, that definitely looks terrible the way it is, but hey, i wouldnt even get that far. :P
Originally posted by ROLLingKINGi have a bronzit and plan on making it look sweet.Originally posted by slammin.e28Moral of this story?
If you drive your e30 on stairs, you're gonna have a bad time.Comment
Finished putting the car together and took it for a 400 mile drive on sunday. Ran strong, but ate a little more fuel than i would've preferred. I am using the m20 flywheel, but i am getting some vibration from it at the low end rpms. otherwise it is really quick and a fun driveComment
89 E30 S52
Transaction Feedback.Comment
subscribed BTW, I am truly impressed.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
Well it is ASC and as far as I can tell it is working. I literally finished all the minor details on wednesday night and then drove the 1200 miles to CA on thursday morning. My car is being stupid though. I greased the crap out of my urethane bushings with Prothane grease, but apparently it all came off during the drive and now my chassis squeaks like mad. My brake booster is making a funny sucking noise as well. Furthermore there is a slight engine misbalance which I believe is due to my m20 flywheel. Just today I noticed a slight engine valve clatter. So in summary... Long trip on untested vehicle=bad idea!Comment
I bought a pre 9/99 E46 323i for the wife. It was the only one I wanted to maintain.Originally posted by 325Projectzdon't listen to the diagram... listen to mr. swiss.Comment
i am curious how you plugged in the speedometer cluster? does everything work?Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
89 E30 S52
