guys using ZF trannys .........
  • nrubenstein
    • 3148
    Originally posted by atldohc
    are you referring to the fact that the clutch engages with the pedal coming right off the floor? this was my experience with those parts. i switched to a e36 325i slave cylinder and this corrected the problem for me. it engages about halfway up now, but the pedal has become noticeably stiffer
    Yes. I'm debating between the E36 M3 master and a 325i slave.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Mr.SWISS
      • Nov 2005
      • 1251
      so is it just me or is there no room to even install this thing (slave)without tilting it(ZF) down?
      Originally posted by 325Projectz
      don't listen to the diagram... listen to mr. swiss.
      :nice:
      • MattM
        • Apr 2009
        • 931
        its possible, an extension with a universal joint makes it easier... 2 extensions with the universal in the middle makes it really easy.
        shove it on, and get the bottom nut started by hand to hold it, then continue with the top one.
        Full Build Thread Here
        • Wh33lhop
          • 11705
          Yep, lots of extensions and a wobble joint have done the trick for me many a time. You can compress the slave slowly if you just apply pressure to it.
          paint sucks
          • Mr.SWISS
            • Nov 2005
            • 1251
            So it seems the consensus is to install it all bled and and line attached I'm getting... Still looks tighter than a chinese virgin. Ordered a UUC line last night so I may put this off today.
            :nice:
            • butters
              • 1206
              Originally posted by nrubenstein
              My E30 clutch master with E36 M3 slave setup is not one that I'm happy with.
              just to throw in my 2 cents here, I'm using a ZF unit with E30 master cylinder, E36 M3 slave and the feel is great. very firm pedal, engages right at the top. I was able to get a really good bleed with a pressure bleeder. clutch is not OEM, though, stage 1 DXD/south bend feramic.
              • Mr.SWISS
                • Nov 2005
                • 1251
                I got used to the Pcar and like the clutch to grab just after letting off/up about 1/4-1/2 travel. Going with the OG E30 slave just need to get a new line this one bent...and the bend back snapped of course so I had to order a freshy.
                :nice:
                • butters
                  • 1206
                  interesting, are porsches known for that? dad had an '88 911 several years ago, unfortunately I never got enough seat time to remember the clutch. but, isn't a low-catching clutch just a symptom of a poor bleed? it's the same basic ssytem as brakes, and perfectly bled best scenario is minimum pedal travel as there is no air to be squished through the lines before actually applying pressure. correct me if I'm wrong here.
                  • Mr.SWISS
                    • Nov 2005
                    • 1251
                    No your theory is all good, IDK why they were like that I thought it was a Porsche thing. I had a 90 C4, 86 951 and ended up in an 86 944 before I finally had enough punishment. You fall in love with the way that cr sounds when you crank, the safe like clunk of the dors shutting and that unmistakable Porsche smell. The upkeep is what killz it. :( S52E30 is damn close to the 911 accel tho for a 6th the cost!!! :up:
                    :nice:
                    • e30rapidic
                      • 2167
                      I have a ZF trans with e30 master cylinder, E36 328 slave and dig it. Pedal is firm but engages close to about 1/3 of the way off the floor. Would love for engagement point to be a bit higher but it enables me to use a bit more ankle leverage than knee since the clutch is very sticky. Helps it not besing so jerky in stop and go traffic.
                      also running Clutchmasters stage 1 e30 clutch setup and e30 325i TO bearing
                      '87 325ic, powered by S50.
