Plenty of time to mod, what to do?
  • willo
    • 23
    I've got a M50 in a 1994 e36 with 114k that I'm interested in swapping into my e30. My e30 has about 145k from the original owners (timing belt change 11k ago) with all service done at the dealership.
    I can take my sweet time with the m50... what should I seriously consider doing to it. I don't mind dropping say, $2k into the engine as long as I can stage it a bit.
    I'll probably use the better trans from the e36 when I do the swap, I'm in no rush at all - I'm happy to toss it on the engine stand and turn it into a fun powerplant.
    Local gas is generally 91 octane, I normally buy 89 for my daily driver, 93 is available, but not always easily.
  • Dj Buttchug
    • Jun 2010
    • 7680
    tarbo can be had for 2k if you source parts yourself
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Adrian_Visser
      • Jun 2006
      • 2823
      2k show me a 2k turbo kit. Don't forget tuning.
      '89 Alpine S52 with goodies
      • ak-
        • 12422
        He said source parts, not kit.
        1991 325iS turbo
        • justin_l_
          • Jun 2007
          • 1079
          Timing belt?
          • Holland
            • Nov 2008
            • 7212
            2.9 stroker.
            Originally posted by DEV0 E30
            • straight6pwr
              • Sep 2004
              • 3450
              chip, big injectors, m3 cams, well-made exhaust, all seals replaced when you have the engine out, any worn accessories replaced, lightweight flywheel, refresh shifter. thats at least 2k.
              • jrdeamicis
                • Nov 2008
                • 956
                The M50 is a useless swap for the E30. Really. Vanos or Non-vanos. I would swap in nothing less than a 2.8. And this is how I would do it.
                Take off all the OBD1 stuff from the M50 motor find an M52 and convert it to OBD1.
                Replace the lifters, get an elring top end and bottom end kit. Do besian seals in the vanos, Find a set of M3 cams, replace all chains and guides, rebuild the oil pump (rebuild not buy) and a tune.
                Buy a decent clutch for it.
                Replace the crank position sensor
                and
                The O2
                And get the head refreshed.
                Thats right around 2 if you do it right.
                Past Car : E30 S50 6 Speed 5 Lug 3.73
                Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                ___________________________________________
                BNB Designs
                Engine Swaps, Fabrication, Innovation, General Repair
                Richmond CA
                Julian 848-248-8029
                • nrubenstein
                  • 3148
                  Use that $2k to get an S50 or S52.
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                  • straight6pwr
                    • Sep 2004
                    • 3450
                    Maybe useless to you. Don't assume everyone wants the same thing out of their e30. I have an m50 and I love it. Although you dont get the HP numbers of an the other swaps, you still get some extra power while saving money. I drive my e30 everyday, I dont need to be able to lose traction every time I accelerate.
                    • jasonsnoddy
                      • 1900
                      i would rather have an m50 that i can put 2k into than an s5x that breaks the bank for just the swap. for a dd ofc.
                      Originally posted by stewie30luvr
                      ooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed it
                      Originally posted by JakeP
                      with a coathanger
                      • JGood
                        • Jan 2004
                        • 7959
                        OP: s50 cams with a proper tune, along with all new seals and gaskets, plugs, water pump, etc...
                        You'll have some $$$ left over. Spend it on the gas you'll use enjoying your 200whp car that cost 1/4 of the 230whp s52 cars :)
                        e30 restoration and V8 swap
                        24 Hours of Lemons e30 build
                        • 325issguy
                          • Dec 2005
                          • 261
                          Iv got the m52 obd1 swap with m3 cams and love it. I would love to run a s50 to see where i stand...
