Relocated stock booster
  • Roysneon
    • 4505
    Has anyone on here slotted the holes and moved their stock booster over instead of replacing it with a smaller one?
    Also is it true that the early models had smaller boosters to begin with?
    Originally posted by mbonanni
    I am a pursit now.
  • StereoInstaller1
    GAS
    • 22679
    1. Yes
    2. No, or at least not mine.
    Closing SOON!
    Thanks for 10 years of fun!
    • Roysneon
      • 4505
      OK, I read about both points on e30tech, so I just wanted to see if there was any validity to them. I definately think I'll just move my booster over then and trim the fins on the intake mani unless a good deal on a 944 booster pops up.
      I am a pursit now.
      • M-technik-3
        • 18946
        Early models seem to have bigger booster in overall diameter but thickness they are smaller.
        • StereoInstaller1
          GAS
          • 22679
          My 3/87 325iS has the same booster as my 9/89 325i.
          Either one could have been replaced in 20+ years though.
          Closing SOON!
          • hoveringuy
            • Dec 2005
            • 2750
            Slotted and moved. I think I got about 1/2", probably not enough for the stock booster but it helps.
            • 89325iturbo
              • Mar 2004
              • 723
              I moved mine over, and shaved the fins. There's not much clearance, but I could of moved mine a little more. I think 5/8 ths is about the limit.
              • e30s50dan
                • Nov 2008
                • 2076
                Make sure you pedal doesn't get in a bind. When I installed my IX booster. I slotted it a little lower which gave room for the e34 mc/resv which gave room for the intake boot. TAHDAH!!!
                NASA
                BMWCCA member
                PCA member 25yrs
                1991 318IS slick top
                1997 M3 sedan
                2001 325CI DD
                “whoever turns the wheel the least, wins"
                • Roysneon
                  • 4505
                  Hm. So I guess even with trimming the fins and slotting the holes I wouldn't be able to use the stock booster on my 84 318. Time to look for a 944/Ix booster.
                  I am a pursit now.
                  • e30s50dan
                    • Nov 2008
                    • 2076
                    Ive owned/raced a few 944's and the brakes are ok,but I really like the feel of my IX booster over the 944.
                    NASA
                    BMWCCA member
                    PCA member 25yrs
                    1997 M3 sedan
                    2001 325CI DD
                    • matt
                      • 3732
                      The IX booster is definitely the way to go.
                      • xwill112x
                        • Jan 2009
                        • 4236
                        i have an ix booster, going to try using the stock one first, if i cant get it to fit, then ill use the ix
                        • M-technik-3
                          • 18946
                          forgotten but the iX booster is pretty much the same as the 530/540 setup in the e34 correct?
                          • White325is
                            • Oct 2006
                            • 5947
                            I slotter the booster and moved it over on 3 different swaps I have done.
                            Moved it to the right 1/2 inch and all was well. I have also notched the intake and plastic welded a new piece in on 2 different swaps and that worked well also..
                            I would def just go with the ix booster. The braking power is much nicer..
                            • M-technik-3
                              • 18946
                              When I did RX7 calipers and the e21 booster it was ok but was too spongy so I tried a bigger MC and that just made the pedal harder. E21 booster is good in a pinch but iX seems to better as it has more vacuum.
