What's the *best* radiator for M50?
  • Charley
    • 396
    Originally posted by BDSax
    wait, the 318is rad has a coolant level sensor??? i dont think mine has one there.
    only the e36 318 one does...
    • BDSax
      Junkyard King
      • Mar 2006
      • 3594
      aaaaahhhhhhhh. will the e36 m42 sensor fit in the e30 m42 rad?
      • Boosted E30
        • Dec 2009
        • 288
        I THINK the rads are the same just the e30 m42 has a cap covering where the level sensor would go.
        • BDSax
          Junkyard King
          • Mar 2006
          • 3594
          anyone know the part number for the e36 318is coolant level sensor?
          • JdmEuroNorth
            • 222
            why are people using electric puller fans with plenty of room in front of the rad for a pusher?
            Function.
            Form.
            • Devil Inc
              • Jan 2008
              • 802
              Maybe possible road debris damage, I've thought about why that is also.
              • BDSax
                Junkyard King
                • Mar 2006
                • 3594
                AC Condensor. i just installed a spal puller so i can go AC
                • samiam3356
                  • Jul 2009
                  • 1901
                  Newer version of the Mishimoto is a PITA for the 2 lines that come from the block and the Expansion tank. They are right on top of one another and make it hard to get the lines on and clamped down. I went with the Mishimoto but might have went with something else to make it easier to bleed and what not.
                  Originally posted by Roysneon
                  $5 shipped?
                  Originally posted by MarkD
                  You are a strange dude, I'n not answering any more posts from you.
                  • tonywonder
                    • Sep 2009
                    • 1688
                    interesting. i have the e36 mishi rad in my 318is. the top rad hose and the overflow hose to expansion tank, are also extremely close together. also a PITA to put those hoses there with clamps.
                    • tomgt325
                      • Jan 2006
                      • 472
                      I have both the m50 and m42 radiator. I am leaning towards the m50, only because I am running the fan delete mod. Does the m42 radiator have enough cooling capacity to handle no mechanical fan, lower temp thermos, water wetter, etc?
                      • DREWHALL
                        • Feb 2006
                        • 1207
                        So are you saying no fan at all? Or just electric fan? If you've got a decent electric in there you should be fine. I've heard of a few people running no fan, but there are too many lights and traffic around me to get away with that and feel comfortable IMO.
                        • Wishno87
                          • 6025
                          I have a 12 inch puller with my m42 rad and it has kept the temp right in the middle so far but then again the car has not seen much more than 80 deg since I installed it. Probably upgrading to a mishimoto this spring.
                          • dude8383
                            • Jan 2005
                            • 10387
                            Originally posted by Fusion
                            THANKS GUYS!
                            Dude: is that an oil cooler behind the right lights?
                            No problem man! That is indeed an oil cooler, I bought one because I wanted to make sure temps are kept in check at the track.
                            • Fusion
                              • Nov 2009
                              • 3659
                              I'm probably going to take fraudulant action and copycat that idea :D
                              I was going to get an E34 M5 oil cooler but they're hard to come by and I was a bit afraid of mounting it low and hitting it somewhere.
                              There's tons of room behind the passenger lights and I can delete the high beam on track days, as I do on the driver side for cool air intake.
                              New project to add to my to-do list.
                              • dude8383
                                • Jan 2005
                                • 10387
                                Haha, go for it :)
                                Have you settled on a choice for the radiator?
