What's the *best* radiator for M50?
  • Fusion
    • Nov 2009
    • 3659
    Ok. I got pissed today.
    The guy who did the swap put in a radiator that cools fine, I don't know what it's out of but the upper flange to the thermostat was shortened, so it doesn't have the bump edge and the upper hose slipped off (second time since buying the car). It has the external exp. tank.
    This is my chance to also get a radiator with a built in expansion tank so I can do the E36 airbox swap.
    What is the best option for good cooling and built in exp. tank?
    I will be buying Nissen's because I can get it for a great price.
    An OEM number would be great.
  • sharky
    • Jan 2005
    • 2672
    M42 radiator w/ built in expansion tank is what you need, either that or relocate your overflow to the rear of passenger front strut tower.
    • Boosted E30
      • Dec 2009
      • 288
      I use the m42 rad no problems yet.
      • herlsy
        • Sep 2009
        • 339
        Best is probably a Mishimoto e36 m3 rad
        • JGood
          • Jan 2004
          • 7959
          Define best. Max Cooling? Cheapest? Size?
          There is no best, it's all what your needs are. If you want max cooling, maybe the Mishimoto would be good for you. For price and size, the m42 is hard to beat. Etc...
          I've never had an overheating problem with my m50, the m42 rad, and a 12" electric fan. Even in 100 degree weather, sitting in bumper to bumper traffic for an hour.
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
          • Fusion
            • Nov 2009
            • 3659
            Best for me =
            internal exp. tank
            cools the m50 no problem, I have viscous deleted, but a good 2 speed spal
            no fabing, just replace the one that's there
            So, since I'm talking euro, M42 rad = early E36 318is?
            Part number: 17 11 1 723 537
            • dude8383
              • Jan 2005
              • 10387
              Originally posted by Fusion
              Best for me =
              internal exp. tank
              The part number / item you want is:
              17111728907
              • etxxz
                • Feb 2006
                • 2085
                same as 325's, fits e30s just as well. i'm rocking it. ~ $150s from ebay IIRC?
                No more e30s for me.
                88 black BMW OBDII 332is dedicated track [sold]
                88 BMW OBDII bronzit 332is [RIP 03/08]
                91 BMW 325i [sold]
                86 Corolla 'Ae86' HB 20v trd [sold]
                http://youtube.com/watch?v=pTj7Hn9v5Rs
                • Killacortes
                  • 1937
                  is the mishimoto rad direct fit into the e30 or does it require some fab
                  r3v does not fuck around. First you get banned, then they shoot you
                  • dude8383
                    • Jan 2005
                    • 10387
                    direct fit.
                    • StereoInstaller1
                      GAS
                      • 22679
                      Originally posted by dude8383
                      That is pretty sexy right thurr.
                      I would like to see a bent metal hard line from the expansion tank to the radiator with just little pieces of rubber tube at each end.
                      I do like that look though.
                      Closing SOON!
                      Thanks for 10 years of fun!
                      • Ara
                        • Jan 2006
                        • 365
                        I have a Mishimoto alu radiator with a spal 16inch fan I believe 2850cfm and running Evans NPG-R " Racing " coolant. AMAZING stuff !
                        The Solution to boilover and corrosion. Preventing Engine Overheating. Evans waterless coolants offer several benefits to save you money, time and engine wear.
                        • ColdAccord
                          • 5926
                          how does the coolant overflow tank work with the rad in e36 m3's
                          Originally posted by blunt
                          • Fusion
                            • Nov 2009
                            • 3659
                            THANKS GUYS!
                            Dude: is that an oil cooler behind the right lights?
                            • BDSax
                              Junkyard King
                              • Mar 2006
                              • 3594
                              wait, the 318is rad has a coolant level sensor??? i dont think mine has one there.
