Critique my S50 parts list!
  • CincinnatiKid
    • Nov 2007
    • 716
    I'm getting ready to tackle an S50 swap on my 91 318is and put together a parts list of stuff I need, so I just wanted to run it by some of you guys with experience and see if I have everything covered, let me know.
    Thanks.
    1990 S50 goodness.
  • Uber E30
    • 1409
    Booster: Dont bother with the THR one, either mod one yourself or buy an IX booster
    ECU: If the ECU is a 506(non ews s50) then yes you reuse that, otherwise you either need a red 413 with a chip or the silver 413 with an ews delete chip(non prefered method)
    Adapter: I would have greg modify your harness for much cheaper
    Motor mounts: Use e28 green hex mounts and save some $
    -Alex
    • JdmEuroNorth
      • 222
      Buy a booster from Jean, works perfect!
      Function.
      Form.
      • e30s50dan
        • Nov 2008
        • 2076
        Go IX booster no spacer. Trust me!!
        NASA
        BMWCCA member
        PCA member 25yrs
        1991 318IS slick top
        1997 M3 sedan
        2001 325CI DD
        “whoever turns the wheel the least, wins"
        • StereoInstaller1
          GAS
          • 22679
          I was under the impression you could use the stock driveshaft.
          Closing SOON!
          Thanks for 10 years of fun!
          • White325is
            • Oct 2006
            • 5947
            There is an IX booster on ebay right now for stupid cheap.
            You going to need a master cylinder for it too.
            You can buy new e21 boosters from autozone for cheap and use your stock master and res. in the end it comes out to be the same amount of money as the IX setup.
            MrEricT on here also does a harness mod and adapters. He has done many and very cheap. Id look into him also.
            The e28 green mounts suck to be honest. I have seen many of them split and the studs break out. The black ones seem to hold up better for some reason.
            • Danny
              • 14216
              Yes if you use the 260 that's true.
              • spaceshuttle
                • 169
                I got a 7 series booster at the junkyard for 25 bucks just need different MC and extended the push rod with a piece of metal from hardware store. I would try a good junk yard before buying a mod booster for $329.
                • hoveringuy
                  • Dec 2005
                  • 2750
                  You'll need a seattlecircuit.com fuel conversion board... car won't run for shit without it!
                  • moh a
                    • 77
                    I'm doing an M52 swap, but what adapter are you guys talking about?
                    • surebimmer
                      • Jan 2004
                      • 978
                      I would buy AKG swap mounts. Broke more then $200 bucks worth in e28 green mounts, just not worth it.
                      • StereoInstaller1
                        GAS
                        • 22679
                        What brand mounts did you kill?
                        Closing SOON!
                        • surebimmer
                          • Jan 2004
                          • 978
                          OEM
                          • dark89e30
                            • 263
                            Somethings not right there. I never see those mounts go bad even when people beat the S out of a E28 with a much heavier engine for years and years. Are you buying Lemforder and are you sure the mounting surfaces are parallel? That mount should NOT break.
                            • e30shmobberr
                              • 1934
                              it is one of the most important things to have for the swap.
                              ex: http://www.treehouseracing.com/index...id=6&Itemid=32
                              Patrick - IG:niicknac
                              RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
