power steering res leaking
  • blunttech
    • 12850
    m52 turbo into 318is... Anyone had this symptom? Theres a small vent hole on the side of the power steering resv cap. After a decent length drive its spraying p/s fluid out that hole. I thought I over filled it so I took some fluid out but i woke up to a huge puddle under the car this morning. Cant see it leaking from any connection. Its almost as if the res is pressurized. With the car running I take the cap off and it looks like the witches brew in there,.. Lots of bubbling and swirling action. and actually a little smoke. In fact I can see smoke coming out of the vent cap when closed. everything but the pump is new ....New rack and resv container. Anyone?
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
  • M-technik-3
    • 18946
    Routed properly? Have to ask.
    • blunttech
      • 12850
      thats my first thought too. Ive done more stupid things. I THINK it is
      sales@blunttech.com
      www.blunttech.com
      Like us on Facebook
      • M-technik-3
        • 18946
        Sounds as the pressure line is your return line.
        • blunttech
          • 12850
          Ill pull up etk diagrams again and go over it again. It confuses my feeble mind
          sales@blunttech.com
          www.blunttech.com
          Like us on Facebook
          • M-technik-3
            • 18946
            Ha know that feeling.
            • blunttech
              • 12850
              I dont know what your situation is with Susanne but you should hang onto that. Any woman that will attempt to replace an ignition switch in an e36M3 is ok in my book. She told me shes already fashioned a removal tool/
              sales@blunttech.com
              www.blunttech.com
              Like us on Facebook
              • z31maniac
                • 17566
                Agreed with M, I bet you switched the lines in a hurry to get it back on the road.
                No worse than me finishing wiring up the swap, cranks, lights work, no BANG. Replaced the fuel pump (thought it was going bad before the swap), still nothing.
                Wake up the next, check the fuse box to see the fuel pump fuse isn't there, run to parts store, replace fuse, car instantly fires up.
                www.gutenparts.com
                • blunttech
                  • 12850
                  well arent they sized so even an idiot cant screw it up? I know on the pump the uppermost port is high pressure. Thats going to my rack after that I forget lol I have to go look
                  sales@blunttech.com
                  www.blunttech.com
                  Like us on Facebook
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    Did you bleed it out when you filled it? Are the lines routed near exhaust/heat/etc. that could cause the fluid to boil?
                    • FredK
                      • 14763
                      It's nearly impossible to hook it up incorrectly, as the pressure lines are M14 and the low pressure lines are M16.
                      I'm uncertain if the low pressure supply hose diameter matters, but the larger of the two hoses supplies the pump, and the smaller of the two supplies the rack.
                      • M-technik-3
                        • 18946
                        Turning the steering wheel is the bleed method. Frothing sounds more like cavatation of the
                        pump. Not boiling.
                        • Farbin Kaiber
                          Lil' Puppet
                          • 29502
                          ^ That was what I meant when I said bleed. Didn't see the frothing word, I did read the words smoking and bubbling however.
                          • blunttech
                            • 12850
                            I kind of thought what fred said and wasnt sure if even I could screw them up. I did bleed the rack with the wheels off the ground turning back and forth maybe 5 or 6 times. Its really fucking up my driveway
                            no lines are running near anything hot as theres nothing hot on that side
                            think its possible i just didnt bleed it enough??
                            sales@blunttech.com
                            www.blunttech.com
                            Like us on Facebook
                            • M-technik-3
                              • 18946
                              interpeted smoking and bubbling as pump caveatting.
