Id describe the smoke I saw as what youd see as blowby if you opened the oil fill cap on a hot motor
power steering res leaking
Had the same problem during my last autocross...then it stopped so maybe it needed to be bled as well...Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
Originally posted by e30s50dan View PostWhat fluid are you useing?
There is also a restrictor in the E36 PS line that youre prob missing...
Check Us out on Facebook
Full Product Line Tuning
Originally posted by 328ijunkie View PostThere is also a restrictor in the E36 PS line that youre prob missing...
Some people argue it doesnt do anything but yeah, it is there on the E36:
Stolen Picture: http://media.photobucket.com/image/E...e/IMG_2340.jpg
Well the one in the E36 is in the return line to the res...
True.
