How did this happen --- Clutch.
  • graphikg
    • Jan 2008
    • 1614
    Ok, for weeks, I have been trying to figure out whats wrong with my car. Vibrations at 1300-2000 rpm, and car will shut off during load at 2k rpm.
    I think I found the problem, tell me what you think.
    This shouldnt be like this right?
    This is not supposed to be like this.
    Another pic
    This what it should look like.
    Ordered a new clutch (F1 racing stage 3). Think I am just throw in a new SSK kit, and tranny and block seals too.
  • matt
    • 3731
    Broken drive straps are generally caused by poor downshift technique (not rev matching)
    • graphikg
      • Jan 2008
      • 1614
      Money shifting you mean?
      • Danny
        • 14216
        No he means slipping the clutch out without bringing the engine RPMs up manually.
        • dirtysix
          • 806
          Heal toe.
            • 34839
            sachs 618...
            • 99em1
              • Dec 2009
              • 200
              Originally posted by nando
              sachs 618...
              plus better rev matching...
              • Syncro325is
                • 574
                loose crank nut/bolt is a possibility
                • nrubenstein
                  • 3148
                  The stock pressure plate does not take abuse well.
                  2002 BMW M3 AlpinweiĂź/Black
                  1999 323i GTS2 AlpinweiĂź
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 AlpinweiĂź/Black
                  • graphikg
                    • Jan 2008
                    • 1614
                    No Way?!? Syncro, can you please explain this... Because I know my crank bolt wasnt to spec when this happened.
                    • zav3n
                      Curious George!
                      • Mar 2007
                      • 223
                      i blew my pressure plate 4 times in 2 months, turns out my thrust Main bearings is worn out and there is too much lateral play on the crankshaft. so it would blow every time i bounced revlimter. m50/getrag 240 euro 323t/o bearing.
                      • graphikg
                        • Jan 2008
                        • 1614
                        Any input on how the clutch can react like this by a crank bolt which is not torqued enough.
                        • u3b3rg33k
                          • Jan 2010
                          • 2452
                          This is NOT how they're supposed to look.
                          THIS is how they're supposed to look:
                          As for what happened to it, my best guess is you happened to it.
                          Ich gehöre nicht zur Baader-Meinhof Gruppe
                          Originally posted by Top Gear
                          Just imagine waking up and remembering you're Mexican.
                          Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
                          • 1990m3
                            • 1180
                            i broke a strap on my pressure plate years ago on an upshift at about 7500RPM. Sachs part in my e30 m3, it was under a year and they replaced it under warranty. Looked like yours, was sheared in half
                            • Van Westervelt
                              • 9365
                              Shift happens.
