How did this happen --- Clutch.
  • jasapp
    • 67
    What brand of pressure plate is that? Are you running an S52?
    I've been having similar trouble (http://www.r3vlimited.com/board/showthread.php?t=175900)
    I've been running a Sachs 618 now for two weeks with no trouble. I'm still holding my breath though.
    • DÌEGØ
      • 690
      Originally posted by graphikg
      Ordered a new clutch (F1 racing stage 3). Think I am just throw in a new SSK kit, and tranny and block seals too.
      hey thats what I got (still sitting in my room) post up how it feels if u dont mind
      Driving:1990 325iS, 2007 335i :devil:
      past BMWs: 1987 325iS turbo, 1989 325i, 1995 525i, 2000 328CI, 2001 540i, 2008 135i
      • graphikg
        • Jan 2008
        • 1614
        ^^^ I would love to. But I ordered the E36 f1 racing stage 3 kit with the flywheel and have found out so far that the alignement tool has to be for the e30 (because of the getrag 260 sized pilot bearing differs from the ZF), and the lightweight chromoly flywheel does not bolt on due to the set bolt hole thingy on the block. The set hole thingy is too large for the holes on the flywheel and I am too chicken to shave it off.
        I am also concerned about the thickness of the flywheel over the lightened m20 one I had on there. It is almost an inch difference in thickness.
        • evil_twin
          • Nov 2007
          • 2965
          So wait... that would cause your car to stall? Please explain...
          Paypal: vdang5@gmail.com
          Delta Auto Care
          2875-C Towerview Road
          Herndon, VA
          703.435.1375
          My Feedback Thread: Evil_Twin
            • 34847
            Originally posted by Syncro325is
            loose crank nut/bolt is a possibility
            the crank bolt holds the hub to the front of the crank, it doesn't have anything to do with the clutch.
            • RickSloan
              • 2401
              it does, because if it is loose it can throw the crank off balance and at high RPM's do exactly this to the pressure plate and cause Knocking at Idle
              Syncro325is will prob come back to this and explain more, but we replaced his PP 4 times before we figured out it was the crank bolt, tightened the crank bolt and it has been abused and fine since.
              Need Illustration or Design work? www.robbiebyerly.com
              • graphikg
                • Jan 2008
                • 1614
                Good, cuz my crank bolt is nice and tight now.
                My car couldnt make it past 2000 rpm under load. I am guessing that the stress on the pressure plate was too much for the broken drive straps and threw out the throwout bearing when it didnt need to and stall. I am not 100 percent sure what was happening in the bell housing. But it would religiously stall at around 2000rpm under load.
