s50 wires
  • 325islovE
    • Feb 2007
    • 133
    s50 wires
    what is this to? I know one plug is for the o2 sensor the other one is???
    s50 053 by reinierrosado, on Flickr
    i got two out of the three relays figured out what kind of relays do i need for the last one?(it has four prongs)use an orange one?
    s50 054 by reinierrosado, on Flickr
    s50 055 by reinierrosado, on Flickr
    1988 325is alpine
    1989 325is zinno RIP
    1992 325ic alpine
    1986 325e cirrusblau
  • M-technik-3
    • 18946
    round is O2
    • blackhawkimpact
      • 2415
      The other one can be for anything. Pull the little boot and check the wire colors.
      • 325islovE
        • Feb 2007
        • 133
        ill pull the boot back tomorrow but its part of the same wire loom as the o2 plug if that helps any.
        1988 325is alpine
        1992 325ic alpine
          • 37829
          Relays are not fuses.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • 325islovE
            • Feb 2007
            • 133
            well thanks my car should fire right up now :)
            1988 325is alpine
            1992 325ic alpine
            • phreshkid
              • 4655
              If it's from the same loom as the o2 sensor, wouldn't that possibly be for the zf tranny? I know mine has a sensor and I labeled it and connected it correctly. That might be it.
              • samiam3356
                • Jul 2009
                • 1901
                I'm throwing my dart at the Vanos Solenoid. You need to run a continuity test to be sure where it goes.
                Originally posted by Roysneon
                $5 shipped?
                Originally posted by MarkD
                You are a strange dude, I'n not answering any more posts from you.
                  • 34839
                  what are the wire colors.. it takes 3 seconds to pull the boot back and look. ;)
                  • BenM
                    • 2184
                    Yup, if its on the same loom as the O2 its likely to be the reverse light plug, which is unused since the E30 reverse lights are wired through the body harness down through the center console.
                    Best to pull back the cover and check the wire colors though.
                    Originally posted by BillBrasky
                    E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
                    1991 318i Alpine II - S50/5-lug swapped - track car
                    1989 325i Cirrusblau - Daily
                    1970 2500 - Malaga over Grey Cloth
                    2012 F350 6.7PSD
                    • 325islovE
                      • Feb 2007
                      • 133
                      the wire colors are blue and green just like the ones that connect to my reverse sensor on my zf transmission.
                      thanks guys.
                      1988 325is alpine
                      1992 325ic alpine
                      • blackhawkimpact
                        • 2415
                        From what engine/year is that harness from?
                        • nrubenstein
                          • 3148
                          I used the E36 plug and ran the wire in through the firewall.
                          2002 BMW M3 Alpinweiß/Black
                          1999 323i GTS2 Alpinweiß
                          1995 M3 Dakargelb/Black
                          - S50B32/S6S420G/3.91
                          1990 325is Brilliantrot/Tan
                          1989 M3 Alpinweiß/Black
                          • 325islovE
                            • Feb 2007
                            • 133
                            should be a 95 m3
                            1988 325is alpine
                            1992 325ic alpine
                            • cabin
                              • Dec 2006
                              • 552
                              It's the plug for the reverse switch in the tranny, if it is in the same "bundle" with the O2.
                              -Justin
                              Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
