new exhaust single 3"?
  • 1991 e30 bmw 318is
    • 523
    rebuilding my exhaust this winter. my 2X2" is getting way to loud and sounds like crap. As it is now it has ebay headers, xpipe, 2 cherry bombs for resonators, magnaflow dual in/out, all 2" pipe.
    new idea is make a nice y pipe, to 3" pipe, with high flow cat, vibrant ultra quiet resonator and a borla turbo 3" in and out.....
    shouldn't be as loud. Less drone in the car? has to sound better.....
    good idea? any suggestions?
    its a m50 vanos with s50 cams... maybe some ITB's later on.
    91 e30 318is M50 SOLD
    http://www.r3vlimited.com/board/showthread.php?t=149570
    92 325 vert project
    http://www.r3vlimited.com/board/showthread.php?t=341370
  • richardb
    • 2121
    Nope, the 3" will be loud no matter what you do.
    Transaction Feedback!
    • e46s54dr
      • May 2008
      • 1059
      A 3 inch exhaust wouldn't be too loud if you simply added a turbo to you car.:D
      • Mike The Bavarian
        • 488
        all false info...3 inch can be made quiet..there's a thread on a 3" recipe somewhere on here. I'll try and find it for you. basically it calls for y pipe, high flow cat, borla xr-1 center muffler(fits perfectly right there) and your muffler of choice.
        • hoveringuy
          • Dec 2005
          • 2718
          I don't think you need 3" for an M50.
          • 416stroker
            • May 2008
            • 2448
            Originally posted by hoveringuy
            i don't think you need 3" for an m50.
            +1
            84 318I Delphin RIP
            87 325IS delphin 24v Sold
            89 325 Alpineweiss
            • Mike The Bavarian
              • 488
              it's the same as have dual 2.25...
              • MaksV
                • 1042
                3" is optimal - it gives great flow and room for motor expansion. check out turners clearance section they have their race borlas - new - on sale for like 120.
                CHEAP REBUILT INJECTORS
                Need Quality Brakes? BimmerBrakes has it!
                For anything Else go with BluntTech!
                • hoveringuy
                  • Dec 2005
                  • 2718
                  It has similar area, but 1/2 the surface area to effect the boundary layer.
                  A single pipe with 20%-30% less area will flow the same as dual pipes... and weigh less.
                  • Mike The Bavarian
                    • 488
                    you're making it more complicated than it has to be. haha
                    alot of people will agree that a single 3" will sound better then dual 2.25, it also weighs less...usually. although you do give up some low end tq for some more topend power.
                      • 523
                      ya the single 3" is not much bigger then my dual 2" set up so don't think its to big... with proper mufflers and resonators should not be as loud as what i have now... and its easier to make lighter and less drone in the car i think.
                      92 325 vert project
                        • 34839
                        total BS
                        and if you have decent headers, the size of your exhaust pipes has *nothing* to do with torque output. Unless it's too small..
                        • evangreen
                          • Aug 2007
                          • 148
                          i have headers Y to 3" all the way back with a straight through magnaflow in the middle and a Borla in the back. no cat. m52 w s52 cams.
                          sounds great and isnt loud at all. Borla is the best
                          • LowR3V'in
                            • 4209
                            Use as many mufflers as you can, and the biggest so it won't
                            be too loud.
                            So don't get a little 14'' rear
                            and no center muffler ect.
                              • 523
                              that's what i was waiting to here.... so what should i use in middle big resonator or a muffler? should i bother with a cat?
                              any vids or your exhaust by any chance?
                              Thanks Jeremy
                              92 325 vert project
