m50 missing and backfiring intermittently
  • JGood
    • Jan 2004
    • 7959
    Originally posted by e30rapidic
    if you have a spare set of coils to try....definitely do that, at least to rule them out if it doesn't fix it. I'm wondering if you have a bad plug still. I was chasing a misfire in my Ford for a long time, turns out it was a plug that had less than 15k on it.
    It was bad enough at times that I had my OBDII diagnostic tool plugged up continuously to reset the CEL and watch engine parameters.
    Thanks, I'll try a new set of plugs. They say BMW on them, so I assume they are old. I've had this engine in my car for 30k miles or so, so they at least have that many. But I'm willing to bet many, many more!
    Originally posted by xwill112x
    have you removed the injectors at anytime?
    Nope.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • JGood
      • Jan 2004
      • 7959
      Are the NGK 2288's a recommended plug for this engine?
        • 34839
        uhm, you can't swap the main and O2 relays. the main relay is a double 87 output. the FP and O2 relays are a single 87 output. you must have swapped O2 and FP relays already. :p
        if the plugs are that old, they definitely need replaced. they're cheap enough that I tend to do mine once a year.
        • shiboujin
          • Feb 2006
          • 2791
          Get a fuel pressure gauge. Just because the pumps work doesn't mean you're getting good fuel pressure.
          Do it. If you blow me off, I will fucking come to your house and CUT YOU. I don't like this "well it gushed fuel when I took the line off" or "I put my thumb on it and it pushed back real hard". Is your fucking finger a pressure gauge? No? Then fucking get a gauge! Fuck. EVERYONE should have a fuel pressure gauge.
          Fuel pressure gauge!!
          TL;DR -> FUEL PRESSURE GAUGE
            • 34839
            a fuel pressure gauge is a good idea, but his plugs are definitely toast and they're also cheaper/easier to replace right meow.
            • shiboujin
              • Feb 2006
              • 2791
              true but the backfire in the intake isn't conducive to spark plugs. It's more than usually fuel related. I'm saying either one of his pumps is bad/clogged or the FPR is dying.
              • e30s50dan
                • Nov 2008
                • 2076
                Bad MAF !? maybe...
                NASA
                BMWCCA member
                PCA member 25yrs
                1991 318IS slick top
                1997 M3 sedan
                2001 325CI DD
                “whoever turns the wheel the least, wins"
                  • 34839
                  but a bad pump won't leave fuel in your intake. it would just go lean. ;)
                  • shiboujin
                    • Feb 2006
                    • 2791
                    a dying pump most certainly will leave fuel in your intake. Atomization will be droplets instead of a mist. Plus if things aren't getting combusted, it goes somewhere. I've seen many cars run lean but leave fuel pooling in the intake.
                    Also, maybe it's a tps issue? Maf is possible but unlikely.
                    • JGood
                      • Jan 2004
                      • 7959
                      I meant I swapped the main and O2 relays with spare relays, off an m20 engine. I couldn't swap the fuel relay because the m20 fuel relay appears to be different then the m50 relay, according to the diagram.
                      I will gladly do that after doing some other simple, free things. I never said I have adequate fuel pressure. Just that the pumps are at least turning on.
                      Originally posted by e30s50dan
                      Bad MAF !? maybe...
                      Already swapped the MAF, no change.
                      • shiboujin
                        • Feb 2006
                        • 2791
                        Sorry wasn't bashing you. It's one of those sore spots for me. There have been many many times fuel pressure was a dead give-away as to what the problem was and people shoved money into other things. Must like people love to have AFR gauges, oil pressure gauges, and volt gauges. Might as well have a useful one like fuel pressure.
                          Backfiring through the intake is caused by; a) a lean condition, b) cam timing error. The first can be a fuel delivery problem or result from intake leaks. As mentioned by shiboujin you need to check fuel pressure. If a check with the car stationary doesn't indicate a problem you need to see what the fuel pressure is doing when the problem is present (zip tie the gage to a windshield wiper). A smoke test of the intake will quickly tell if intake leaks are a contributor.
                          • JGood
                            • Jan 2004
                            • 7959
                            Is there an easy way to read fuel pressure while driving? Can I 'T' into the fuel line and run a hose through the window to a gauge or something? The car only misses every once in a while, so I doubt I'll see a major problem while idling. It goes away completely above 4k or so, so if I'm getting fuel at 7k RPM's and full throttle, something tells me it's not a fuel flow issue.
                            The problem is mostly noticeable at about half throttle between 1500 and 3500 RPM's. I can drive a few miles, stop and go, and it won't do it. Then all of a sudden it will miss once or twice, then maybe I can go a few miles again, or maybe it will do it a few more times. Very inconsistent. It hasn't been backfiring much at all lately. Maybe on average once a day during my 70 mile round trip commute. Just missing.
                            • JGood
                              • Jan 2004
                              • 7959
                              Thanks for the info. I remember looking into a smoke test before, but it seems like the quality test machines are expensive and only found at garages. Would probably be cheaper for me to just replace all the vacuum connectors/hoses/gaskets! (Many of which are new)
                              • shiboujin
                                • Feb 2006
                                • 2791
                                Some gauges have electric senders. otherwise you can just run an extra long fuel line and run it outside of your hood. But intermittent still mean you might have low fuel pressure all around.
                                Also, I'm starting to suspect your TPS. I didn't read if you swapped that out.
