US vs. Euro s52
  • SwiftE30
    • Jun 2010
    • 998
    US vs. Euro s52
    What's the difference? I found the specs on a website that said the euro has roughly 35 more HP than the US, as well as a faster 0-60 by .3.
    What is different between the two?
    1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
  • Danny
    • 14216
    Search. God damn.
    • imdashiz
      • Sep 2009
      • 1373
      Originally posted by Danny
      Search. God damn.
      PSN ID: Yourself1
      • dinanm3atl
        • Feb 2007
        • 7305
        What different? Almost everything.
        • Uber E30
          • 1409
          well since there is no euro s52, there is a great difference
          -Alex
          • imdashiz
            • Sep 2009
            • 1373
            most noticeable things are the beautiful ITB's
            PSN ID: Yourself1
            • CincinnatiKid
              • Nov 2007
              • 716
              1990 S50 goodness.
              • bmw325csi
                • May 2007
                • 4045
                US: souped up m50/52
                EURO: Real ///M engine
                harry/harout
                • Chrisv006
                  • 375
                  • SwiftE30
                    • Jun 2010
                    • 998
                    Search. God damn.
                    just curious man, no need to be a dick. Im sure you've had some retarted questions in your BMW career...
                    • calz4m
                      • Aug 2009
                      • 96
                      Think of the Euro S50B32 as an early S54 (without all the electronics). As someone mentioned,the S52 is basically an upgraded M50/M52. Entirely different engines. With the increasing availability of the S54 for swaps it's becoming increasingly harder to justify the Euro engine route. Pricing is probably similar between the two, but I have no data to support that claim. Guessing both are around 5K(ish) with a harness and ECU. If you are a real purist then putting the S50B32 into an E36 M3 would be the move. Otherwise, S54 all the way.
                      • eandrade
                        • Jan 2007
                        • 117
                        One is prettier and makes neat noises.
                        1990 325i
                        • M3 euro ltw
                          Site Sponsor
                          • 259
                          E36M3 engine varieties: US S50, S52, Euro S50B30 & S50B32
                          US M3 (240 hp)
                          Conrod bearing size 45mm
                          Two setting Vanos. (nl or advance, not variable)
                          Headers of suboptimal design
                          Hydraulic self adjusting valves
                          WP is of questionable quality
                          No oil cooler provision (First M engine to lack this)
                          Single TB. (May favor torque, but certainly not HP)
                          S50B30 (286 hp)
                          Max HP 286 at 5900 rpm
                          Max Torque 235 at 3600 rpm
                          Redline 7200 rpm
                          Conrod bearings are 50mm
                          Forged Rods
                          Intake vanos is continuously variable (30 deg?) each direction
                          Headers are equal length, preserve torque (no O2 bungs)
                          Bucket/Shim set up for valves, needs interval maintenance
                          Excellent wp and thermostat set up manifold provides thermostat and oil cooler
                          Insulating ceramic spacers between header and cylinderhead
                          Motronic dme and separate vanos controller, both “chippable”
                          6 TB set up
                          Late versions include EWS II
                          Catalytic had O2 bungs pre-cat only.
                          S50B32 (321 hp)
                          Max HP 321 at 7400 rpm
                          Max Torque 236 at 3600 rpm
                          Redline 7600 rpm
                          Conrod bearings are 49mm
                          Sintered rods after 10.96 (I think)
                          Intake and Exhaust cams continuously variable
                          Headers improve slightly on 3.0 weight and thickness, include O2 bungs
                          Dual pickup oil pan
                          Compression bump from 3.0 version
                          Ceramic spacers no longer included
                          Siemens DME flash only, Vanos controller incorporated into main DME
                          MZ3 versions may have EWS III
                          Trying to make the world a better place, 6 TB at a time.
                          http://abloriginalparts.com/
                          • digger
                            • Nov 2005
                            • 6188
                            Fixed some errors for the S50B32
                            Originally posted by M3 euro ltw
                            US M3 (240 hp)
                            S50B30 (286 hp)
                            Redline 7200 rpm
                            Forged Rods
                            6 TB set up
                            S50B32 (321 PS)
                            Max HP 316 at 7400 rpm
                            Max Torque 258 at 3250 rpm
                            Redline 7600 rpm
                            Dual pickup oil pan
