Best / Modern Fuel Pump Replacement
  • Lakis
    • Mar 2007
    • 160
    what is everyone replacing their fuel pump with?
    Factory/Orig pump: 16141179232 OR
    I've been referred to these Bosch aftermarket:
    Bosch: 0580254044
    Product Information
    [SIZE="1"][SIZE="3"][SIZE="4"][SIZE="3"]Minimum Current: 12 Volts
    Operating Pressure: 72.5 PSI (5 Bar)
    Minimum Flow @ Outlet: 80 GPH (300 LPH)
    Fuel Pump Location: In-Line
    High Temperature Reduction: 8 GPH (30 LPH)
    Weight: 1030 Grams (2.27 Pounds)
    Fuel Pump Connections:
    Inlet: M18 x 1.5
    Outlet: M12 x 1.5
    Electrical: Positive M6 / Negative M5
    John K
    Park City, UT
    1991 BMW E30 M3 S52
    2003 Audi A4 Avant 1.8T
  • herlsy
    • Sep 2009
    • 339
    I just replaced my in tank pump (dont have an external) with a TRE 340, very quiet and seems to do the job so far.
    The Racers Edge Performance - TRE 255 LPH Fuel Pumps offers new ford mustang, chevrolet camaro, and import performance fuel pumps similar to the Walbro 255 lph, at cheap discount wholesale prices, including fuel pumps similar to walbro 255lph for all model cars, domestic and import.
    • White325is
      • Oct 2006
      • 5947
      I run a tre pump as well. never a problem and like said above it is very quiet.
      • 10Toes
        Me Father Was A Tree
        • Jan 2008
        • 61222
        Walbro 255 fuel pump -GSS-340
        • matt
          • 3732
          Factory pump or a walbro.
          The 044 is massive overkill, even for a turbo DOHC e30.
          • Lakis
            • Mar 2007
            • 160
            Ok- so I have an E30 M3 fuel supply system still. So, I have an in tank and one by the driver's side rear tire.
            you're recommending the TRE one for the pre pump in the e30 /m correct? Is it a better swap or is it just less expensive?
            I would have to keep the pickup and just change the internal pump itself.
            thanks
            John K
            Park City, UT
            1991 BMW E30 M3 S52
              • 34847
              the bosch pump definitely owns all
              be careful though, you'll likely want to use the stock in-tank pump as a transfer pump and the bosch pump externally. The in-tank version won't fit inside the E30 pump opening. the walbro 255 won't be able to touch it in this configuration (especially if you get a crappy made in china copy).
              • 10Toes
                • Jan 2008
                • 61222
                • Lakis
                  • Mar 2007
                  • 160
                  Thanks!
                  So, gonna get both new since they're both original and are 20 years old.
                  External: going with the BOSCH 0580254044
                  Internal: going with Stock BMW P#: 16141179415
                  Do you recommend changing that "absorber" that is before the fuel filter?
                  :D
                  John K
                  Park City, UT
                  1991 BMW E30 M3 S52
                    • 34847
                    throw it away and replace it with a new peice of fuel-injection rated fuel line.
                    • FredK
                      • 14763
                      The 044 won't fit in the stock location?
                        • 34847
                        the inline version will fit where inline pumps fit, but the in-tank version does not fit. I tried. :(
                        • JdmEuroNorth
                          • 222
                          Also running the walbro 255.
                          Picked it up for just over 100 bucks shipped off ebay!
                          Function.
                          Form.
                          • matt
                            • 3732
                            If anybody needs a walbro pump, I have them. :)
                            • etxxz
                              • Feb 2006
                              • 2085
                              walbro 255 fuel pump -gss-340
                              +1
                              No more e30s for me.
                              88 black BMW OBDII 332is dedicated track [sold]
                              88 BMW OBDII bronzit 332is [RIP 03/08]
                              91 BMW 325i [sold]
                              86 Corolla 'Ae86' HB 20v trd [sold]
                              http://youtube.com/watch?v=pTj7Hn9v5Rs
