m50 turns over but wont start. Fuel problem?
  • Oz10
    • Jul 2009
    • 640
    So last night I finally had everything together and went to crank my m50 swap for the first time. The starter will spin and the engine will turn, but it won't fire up.
    I've tried replacing the fuel pump and main relays that are on the m50 wiring harness. I replaced the fuel pump fuse in the e30 fuse box too.
    I've also switched the main and return fuel lines to see if they were in the wrong place.
    It doesn't look like the lines are getting fuel, which makes me think the fuel pump isn't running.
    Has anyone experienced this or have any suggestions on what the problem may be?
    The engine is a m50nv and the car is a 89 325is. Thanks!!
  • e30s50dan
    • Nov 2008
    • 2076
    Sounds like you need to first start at the pump and see if you got 12v. Then go from there. What you could do is spray a little starting fluid in the intake but remove your maf first , spray and see if it wants to start,then go from there. Good luck
    NASA
    BMWCCA member
    PCA member 25yrs
    1991 318IS slick top
    1997 M3 sedan
    2001 325CI DD
    “whoever turns the wheel the least, wins"
    • gregslow318i
      • Sep 2007
      • 1918
      your crank and cam position sensors are switched at the harness and the dme is not seeing a rpm signal....hence no pump voltage
      looking for a e30m50 swap harness adapter pm me $150 shipped
      email nitroman12@gmail.com
      • Oz10
        • Jul 2009
        • 640
        I really appreciate the help guys! I'll check it out tomorrow.
        Keep the suggestions coming!
        • Oz10
          • Jul 2009
          • 640
          Looks like the plugs aren't sparking either. Could it be a ground?
          • Adrian_Visser
            • Jun 2006
            • 2823
            He's onto something there.
            '89 Alpine S52 with goodies
            • Oz10
              • Jul 2009
              • 640
              I didn't mess with either of these sensors though. I'm wondering if maybe the plug on the otherside is undone. I have a three pronged plug under the intake area and I have no idea where it goes. I guess I'm going to take the intake manifold off and see if anything looks off under there.
              • gregslow318i
                • Sep 2007
                • 1918
                what color are the wires on the plug that is not connected. also have you checked the crank position sensor (ome'ed out or replaced with a know good one)
                • Oz10
                  • Jul 2009
                  • 640
                  The wire to the plug that isn't connected is black. Ill try to take a picture of it. Would the crank sensor cause it not to spark?
                  • tweetyoost
                    • Jan 2010
                    • 10
                    Hi!
                    I'm at that same problem, but it's in a 1985 320i Euro chassis.. (with the old electrics:p )
                    I've put the (external)fuel pump directly at 12v to make some pressure. And then tried to start but it looks like the fuel injectors aren't working.. And I guess the DME won't work aswell. I'm trying to figure it out as soon as possible.. I keep watching this topic ;)
                    So... you can mix the crank and camshaft sensor? hmm I didn't touch them..
                    • gregslow318i
                      • Sep 2007
                      • 1918
                      no, you need to peal back the boot covering the end portion of the plug to expose the wires under the black wrapping
                      • Oz10
                        • Jul 2009
                        • 640
                        I pulled back the boot and the wires are blue/white, blue/green, and brown
                        • Oz10
                          • Jul 2009
                          • 640
                          Does anybody know what that plug is for?
                          • 416stroker
                            • May 2008
                            • 2448
                            Take a pic of the plug
                            84 318I Delphin RIP
                            87 325IS delphin 24v Sold
                            89 325 Alpineweiss
                            • RSGM
                              • Nov 2008
                              • 425
                              RIP
                              Photo By: D.Tek
