m50 turns over but wont start. Fuel problem?
  • Oz10
    • Jul 2009
    • 640
    #31
    Originally posted by 416stroker
    Bad cps IM shocked know ones said that yet.
    I'll try replacing that as well. The shop I work at has a e34 parts car so I can snag it off of that.
    • Oz10
      • Jul 2009
      • 640
      #32
      Any idea what this plug is? And is it important? I is near the DME coming from the m50 wiring harness
      • Oz10
        • Jul 2009
        • 640
        #33
        So I replaced the cam sensor today and I haven't noticed an improvement. I'll try to get the crank sensor swapped out tomorrow. I sprayed some starting fluid in the intake manifold and went to crank the car and it tried to start up. One of the techs at work said that he's seen BMW's do this before with no spark. Has anyone else heard of this happening?
        • evil_twin
          • Nov 2007
          • 2965
          #34
          Why don't you do the pedal dance and see what codes pull up before you just start buying parts?
          Paypal: vdang5@gmail.com
          Delta Auto Care
          2875-C Towerview Road
          Herndon, VA
          703.435.1375
          My Feedback Thread: Evil_Twin
          • Oz10
            • Jul 2009
            • 640
            #35
            What do you mean by pedal dance? I haven't spent any money on parts, I've got a parts car to pull from at my work. I'll run codes tomorrow thats a good idea.
            • evil_twin
              • Nov 2007
              • 2965
              #36
              eh, pedal dance is the turn key on, stomp gas pedal 5 times within X amount of seconds, then read codes.
              Delta Auto Care
              Herndon, VA
              703.435.1375
              • Oz10
                • Jul 2009
                • 640
                #37
                Oh okay got ya
                • tweetyoost
                  • Jan 2010
                  • 10
                  #38
                  I noticed this aswell. I tought my spark plugs are firing but you can only be sure if you but one coil out, tape a spark plug to it and ground it. If you see sparks.. it does work..
                  • Oz10
                    • Jul 2009
                    • 640
                    #39
                    Just switched out the crank position sensor. Still nothing
                    • monkeytaco
                      • Jan 2010
                      • 882
                      #40
                      This entire thread sounds like a wiring adaptor problem. I'd go over your connections pin by pin to verify they are correct.
                      I have an m50nv manual harness from a 92 325 in perfect shape if you need it. $100 shipped.
                      Looking for a clean e30 shell for a project.
                      • 328ijunkie
                        • May 2007
                        • 3961
                        #41
                        Crank Pos sensor and ECU relay are the two things that usually cause no spark no fuel.
                        Check Us out on Facebook
                        Full Product Line Tuning
                        • tomgt325
                          • Jan 2006
                          • 472
                          #42
                          I am in the exact boat right now and in the middle of testing the same things. Good luck, and I'll post up if I find a solution.
                          • Oz10
                            • Jul 2009
                            • 640
                            #43
                            I don't think its the harness thats the problem. I'm thinking its probably the adapter.
                            I've already tried both of those. :(
                            Good luck man, let me know when you find out what's wrong with yours.
                            • 328ijunkie
                              • May 2007
                              • 3961
                              #44
                              Have you tried hardwiring the fuel pump and ECU relays?
                              • Oz10
                                • Jul 2009
                                • 640
                                #45
                                I hardwired the fuel pump relay. I guess I can try hardwiring the ECU relay at the same time and see what happens. I can get the fuel pump to run if i hardwire the relay, but the injectors aren't working.
