finally got my s50 =]
Haha I hear ya man. I am just wrappin up my m50 swap and my gf asked "what are you gonna do when its all done"? My response, "You can be done?!?!?!"Originally posted by AlpineS50E30thanks man :o, and you took the idea right from my head!!! i plan to do that with the valve cover, probably during spring time, i mean cmon, there's always more things we wanna do to our e30's, right? =p
What are your plans for exhaust?
M50B25tuComment
exhaust is on today, although it's leaking from the manifold, gonna fix that next week, i ran two back to back resonators, 2.5 inch all the way back to a magnaflow muffler, with a simple tip, it's quiet. and yes, no cat.check out my swap thread =]: swap thread
question for everyone, my s50 runs greats, one issue though, it hesitates if i floor it and come up on power quick, only issue is the minor exhaust leakat manifold i have...could it be the 318 pump i have not supplying enough volume of fuel? i'm running the 3.5 MAF with AA tune up to 7400 rpm's, fuel pressure is at 50 psi idle.check out my swap thread =]: swap thread
or can an exhaust leak on an s50 cause it to hesitate sometimes? also, on occasion, it misfires at idle.check out my swap thread =]: swap thread
Quiet is important in NY trust me i know lol assholes gave me a ticket as i was parking in front of the house. Good luck working out your minor issues, should be around tomorrow or sometime during the week i gotta come see this thing, btw text me i lost my phone a few weeks ago and all my contacts.Comment
ok so, fixed the hesistaion, didn't know AA software needs the VSS hooked up to run properly, runs a lottt better, i've decided i'm going to change the fuel pump anyway, i feel like it's holding back, going to put a walbro pump, and should be fixing the exhaust manifold leaks this week sometimes.:)check out my swap thread =]: swap thread
I believe the walbro and the stock pump have the same flow rate, no?ok so, fixed the hesistaion, didn't know AA software needs the VSS hooked up to run properly, runs a lottt better, i've decided i'm going to change the fuel pump anyway, i feel like it's holding back, going to put a walbro pump, and should be fixing the exhaust manifold leaks this week sometimes.:)IG: deniso_nsi Leave me feedback here
nop, stock pumps are 190 LPH walbros are 255
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
