Overheated aluminum m52
  • lennon
    • Jun 2008
    • 1416
    A guy I know has an e46 323i with coolant in the oil. Cyl. 3 and 4 were full of coolant I pulled the head and the gasket looks fine, took the head in and it's not cracked, but is warped a bit. My question is: Is it common for these blocks to crack?
  • Eecen
    • Jun 2010
    • 1235
    Read up on e46fanatics?
    but really...
    Did you re-torque the head bolts before pulling the head?
    Apparently when these things overheat the head bolts have a habit of "stripping" the block..ie head bolts will not hold proper toque.
    Seems like that could well be the problem?
    • Adrian_Visser
      • Jun 2006
      • 2823
      Pretty sure that once the Aluminium blocks are overheated BMW considers them to be scrap. From a warranty point of view I believe they would replace the whole engine. Ye be warned.
      '89 Alpine S52 with goodies
      • hoveringuy
        • Dec 2005
        • 2721
        The block will need to be Timeserted. The head will need to be heat straightened, skimmed and have the valves re-seated at a minimum.
        I don't know if it's worth it on a 2.5litre.
