Under load, 3krpm turn off. Vanos Discon, doesnt turn off.
  • hoveringuy
    • Dec 2005
    • 2711
    100 Ohms will keep the ECU happy, you don't have a problem there.
    You have sufficient current for the MOSFET current sensing.
    • unevakno
      • Dec 2010
      • 1
      Any updates?
      • e30rapidic
        • 2167
        bump - what happened here? resolution???
        '87 325ic, powered by S50.
        • graphikg
          • Jan 2008
          • 1614
          I just posted on your thread... If I had a resolution I would be at an autoX right now and I would have posted it.
          • 328ijunkie
            • May 2007
            • 3961
            Idea!:
            Is the cam sensor pickup on the intake cam properly? its easily possible to rotate it 120 deg offset and thus mess up what the ECU sees as cam timing. I have done this before so i know.
            Look at this picture:
            see the bump in the triangle? There should be a bump to match it on the sheet metal cam sensor pickup.
            Check Us out on Facebook
            Full Product Line Tuning
            • graphikg
              • Jan 2008
              • 1614
              Finally found the solution!!!
              Apparently, the head and the block have gone through enough resurfacing over the years that the clearance between the valves and pistons became less and less. SO whenever the vanos would engage, the valves would hit!!!:eeek: I guess this would trigger the knock sensor and shut the car off. Without vanos engaging, the car would run with no problem.
              Bavarian Motorsport in Milpitas figured this out. Ramon there retarded the intake cam to drop at a different time so it wouldnt contact; and the exhaust cam was advanced. Plugged in the vanos and BAM! Car is back to perfect. Feels strong. I just got to get used to this noisy and roguh stage 3 f1 racing clutch now. HAHA... But it feels strong and I am happy again. Price was very reasonable too!
              • samiam3356
                • Jul 2009
                • 1901
                wow, Thanks for posting the solution. Guess none of us internet mechanics saw that coming. lol
                Originally posted by Roysneon
                $5 shipped?
                Originally posted by MarkD
                You are a strange dude, I'n not answering any more posts from you.
                • e30rapidic
                  • 2167
                  awesome!! That's probably something nobody on here would have thunk up!
                  good news!
