M50 cooling issues
  • shiboujin
    • Feb 2006
    • 2791
    M50 cooling issues
    Finally got the car bled today with a new 71C thermostat. I have a mishimoto rad and a pusher AND puller fans. pusher is 2400CFM and puller is 1600 CFM.
    The car now holds a good temp ~177F. But the heater blows cold at stops. IE if I drive, I feel heat. If I stop, it slowly goes away and temps start to climb a bit (not too far and settles after a second). I'm guessing I have bubbles in the heater core.
    I'm gonna try what I found here: http://r3vlimited.com/board/showthre...=bleed+coolant
    If anyone else has ideas let me know!
    • 34839
    you have air in there somewhere.
    I always bleed with the resivior cap off, bleeder screw open, and heater controls on hot - rev the engine a bit while you fill the resivior. when it stops bubbling or starts to boil over, close it up. never had it not work that way..
    • shiboujin
      • Feb 2006
      • 2791
      I have no bleeder screw. I've never seen an M50 with one. It likes to "belch" now and then and push coolant out the res then suck all the way down again. But it has basically stopped that I think.
      • samiam3356
        • Jul 2009
        • 1901
        You loose the bleeder screw with the Mishimoto. Try jacking the front end up a bit.
        Originally posted by Roysneon
        $5 shipped?
        Originally posted by MarkD
        You are a strange dude, I'n not answering any more posts from you.
          • 34839
          yeah, it's in the radiator on the E36. hah, another reason not to use shitty chinese parts..
          • 328ijunkie
            • May 2007
            • 3961
            coolant hoses backwards at Hcore?
            Check Us out on Facebook
            Full Product Line Tuning
            • Dominic49
              • Feb 2007
              • 1373
              its in the expansion tank not the radiator. another reason not to spread shitty missinformation...
              • samiam3356
                • Jul 2009
                • 1901
                Was thinking this. Looked at mine the other night and my valve was on top. Had to tear everything apart but cleaned some things up.
                $5 shipped?
                • shiboujin
                  • Feb 2006
                  • 2791
                  I used to have heat. Nothing has changed in the physical setup so I'm sure it's on right.
                  • samiam3356
                    • Jul 2009
                    • 1901
                    It takes no time to yank the console out and look
                    $5 shipped?
                      • 34839
                      Uhh, semantics? Considering I just filled and bled the cooling system in an e36 m3. The point is he has no bleed screw.
                      • samiam3356
                        • Jul 2009
                        • 1901
                        But that radiator was designed for the e36. They don't make one for the e30 just the e30m. Many people use them on their swaps and I have yet to see anyone complain or have issues with them.
                        $5 shipped?
