Transmission's for m50
  • 1fastm50
    • Aug 2009
    • 342
    Ok so I've been searching for a while and am so confused. Can an eta transmission be used with an m50? I believe the one I have is a 260 from an eta. I've heard only late model ones fit and early model ones don't unless u shave the flywheel.
    Racelands are cheap shit.
    Originally posted by whodwho
    So are r3v members
    dude, this is R3v. there's like 40 project threads, and like 20 FS threads and 100 members ride threads of stupid shit. guaranteed laughs on every page. cut springs, rolled cars at 20mph, fishtank heater core, selling broken stuff, painting cars with paint brush, cheap wings, hella-flush and then there is Vlad, king of the eta M3
  • Pussy30
    • Feb 2011
    • 463
    I have a 260 on my m50, unfortunately its on its way out.
    • 1fastm50
      • Aug 2009
      • 342
      So it's a direct fit? With all the flywheel and PP from the 260. Is it on it's way out because of the m50 or was it on the way out already? Thanks for the help.
      So are r3v members
      • green
        • Dec 2010
        • 128
        I didn't know there was a difference between which g260 was used. Wouldn't be the first time I was wrong though. I'd kind of like to know this as well because I was thinking about a 24V swap into my '87 eta.
        • Danny
          • 14216
          Hokay, if you wanna use the g260 with a 24v motor you need a custom trans brace. Your fly/clutch options are as follows: e36 flywheel and clutch with e36 starter and g260 pilot and throwout bearing OR m20 fly/clutch with m20 starter and g260 pilot and throwout bearing. Both use the e30 slave cylinder. Hokay? Hokay.
          Also, if this is an early trans with a sheet metal shift console you'll need the later model aluminum arm to get the shifter to sit right, otherwise its a total pain in the ass. So i guess you don't NEED it, but you should WANT it.
          • 1fastm50
            • Aug 2009
            • 342
            Alright got it thanks for the help guys.
            So are r3v members
            • luis.e30325es
              • Feb 2011
              • 128
              I am trying to purchase a transmission modified cross-member for my m50 swap, but i have had no luck finding it, if you guys could let me know how or where i can order one that would be great. trying to start my swap this weekend.
              • Matt-B
                The Waffler
                • 3856
                ya PM white325is
                • luis.e30325es
                  • Feb 2011
                  • 128
                  ok thanks man
                  • Adrian_Visser
                    • Jun 2006
                    • 2823
                    I used the e36 TO bearing with my e36 flywheel and clutch, pretty sure it's what you need in that case.
                    '89 Alpine S52 with goodies
                    • UDelaware30
                      • Dec 2009
                      • 336
                      Originally posted by Matt-B
                      ya PM white325is
                      +1
                      i have one in my car and it lines up perfectly. Nice piece from a good dude.
                      • Danny
                        • 14216
                        I used whatever TO bearing was already in the car. Which woould bee the stock e30 one. I guess either is okay.
                        • mcr_driver
                          • 4491
                          question regarding throwout bearings. Why is it for the getrag 240's you need to use the euro throwout bearing? Never received or found a definitive answer on this...
                          • FKNFASTM5
                            • Apr 2007
                            • 493
                            i would like to know that as well
                            • Adrian_Visser
                              • Jun 2006
                              • 2823
                              The Euro TO bearing is thicker. I believe it effects pedal travel.
