hmm...interesting...does anyone have the specific part# needed?
Transmission's for m50
Originally posted by Danny View PostI used whatever TO bearing was already in the car. Which woould bee the stock e30 one. I guess either is okay.
Originally posted by mr2peak View PostWho has run both the 260 and the ZF? Is there a noticeable difference?
I have the 260 with a 4.10 in the car now, but I also have a ZF and a 3.25 laying around that I was thinking about installing.
Yeah first gear is kinda sad, really easy to peel out in the rain. Feels like first gearing is holding you back. I never pull on people in 1st, have to get to 2nd to go anywhere.
Good news is that I don't have to shift from stop sign to stop sign when I'm lazy, just leave it in 2nd and go.Drive it hard. Maintain it well.
A Topless Memorandum
Getrag 265 with s50?
Ok guys, I am looking for an answer I hope you can help. I have an e30 M3 w/a hybrid s52 bottom end ltw. flywheel/m5 clutch, with OBDI top end and schrick cams and ZF320 trans and 3.25lsd.
I was looking at swapping out trans for a Getrag 265 with OD 5th daily driver. Would the 265 need the modified cross member as used for the 260? I have the removalable bell housing from an eta. As I understand the m/s50,m20 have same bolt patter for trans.
Originally posted by ninerm3guy View PostOk guys, I am looking for an answer I hope you can help. I have an e30 M3 w/a hybrid s52 bottom end ltw. flywheel/m5 clutch, with OBDI top end and schrick cams and ZF320 trans and 3.25lsd.
If you have already sourced the bell housing from the E28 eta, then you will be able to bolt it up to any M5x/S5x, however since there is about 10 degrees of extra slant angle going from an M20 to a DOHC motor the trans will be "twisted" over some, and you will likely need a custom trans brace.
Again, though, I cannot see a good reason to do so. The 265/6 has almost identical gear ratios to the G260, and the ZF is really better suited to an S5x anyway as the first gear is a little taller and less useless. Save the removable bell housing for a dogleg 265!paint sucks
