no sark, has fuel, but injectors are dry
  • Joe G
    • 2948
    as the title states. The car is cranking, there is fuel in the rail, but there is no spark.
    Help.
    Current Car: 2011 BMW 135i, M-Sport, 6 speed
    Originally posted by lambo
    Sounds like you need a massage.
    Originally posted by kpeng
    Who the hell is Vlad?
  • Adrian_Visser
    • Jun 2006
    • 2823
    Do you have spark?
    '89 Alpine S52 with goodies
    • nrubenstein
      • 3148
      With no spark and no fuel, look to the DME, or one of the critical sensors (CPS).
      First and foremost, do you have a non-EWS DME? (413 red label, for example.)
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • Joe G
        • 2948
        CPS is reading 505ohms, and the plug that it connects to shows 3.3volts. That seems awfully low.
        The ECU chip was installed backwards by the clown who started and bailed on the build. I flipped it around and that got the fuel pump working, but still no spark or injector fire.
        I forget what the DME is, but im 90% sure its not a red label 413
        • Adrian_Visser
          • Jun 2006
          • 2823
          If it's a silver label 413 or a 506 you are going to need an EWS delete chip. And did I have epic reading failure or did you edit the OP?
          I recommend you check the resistance at the DME connector to make sure you have the right connector hooked up to it. The CPS is pins 43 and 16.
          • Joe G
            • 2948
            Who sells EWS delete chips? Its got a turner chip for a bigger MAF and 24lb injectors.
            just a read failure.
            • Adrian_Visser
              • Jun 2006
              • 2823
              Pretty sure turner does, Honestly It would be cheaper to find a red label 413 than buy a chip if that is in fact the problem.
              And wow, I ken readz good
              • Joe G
                • 2948
                ok, thanks. Ill see if i can swap the chip i have from turner for the right one. likely plus some cash.
                • Adrian_Visser
                  • Jun 2006
                  • 2823
                  Well how about you make sure that's the problem first. Test the resistance at the DME connector like I suggested.
                  • Joe G
                    • 2948
                    according to mike (guy who half assed the swap and then dumped it on me) the chip is an EWS delete chip and its brand new from turner. If that is in fact true, what are other possible reasons for my no fuel injector fire, and no spark issue.
                    • FredK
                      • 14764
                      Open the DME and confirm there is a chip.
                      Then confirm it is plugged in correctly. If it's plugged in backwards, it won't work.
                      • Joe G
                        • 2948
                        the chip is there, and it was plugged inn backwards. before i switched it around the fuel pump wasnt running. Once i flipped it the fuel pump turned on, but still no spark. I pulled a coil pack and put in a brand new plug, then grounded it and cranked the car. Its confirmed no spark.
                        • Adrian_Visser
                          • Jun 2006
                          • 2823
                          I recommend you check the resistance at the DME connector to make sure you have the right connector hooked up to it. I.e. check the resistance between pins 43 and 16.
                          • Joe G
                            • 2948
                            thanks will do! Ill update the thread first thing tomorrow morning.
                            • Joe G
                              • 2948
                              if there is no power on pins 43 and 16, what should i check next? same question for if there is power to those pins?
